Web Access to my node with asl-web-ui
I have a unique problem I think. After disconnecting my Wi-Fi link and then reconnecting it, I am able to connect to asl-web-ui but only with http:// not with the secure mode https//. After a period of time, such as a one day, I can no longer connect to asl-web-ui either with http://: or https:// I just can no longer connect at all.
While I am still connected after a Wi-Fi re-connect, I went to the network tab and it displayed: HTTPS port 433 on, Certificate Self-signed expires 2/24/29, cerbot Installed, renewual timer active.
I have shut down my firewall completely and I still cannot get in. I am on the same local network with the pc trying to log in and the debian 13 server running allstar.
What am I doing wrong? Any further info needed?
Are you sure port 433? https is normal handle on 443.
Can you be more specific on what "no longer connect" means? Are you getting an error? A strange screen? A timeout? We need more info to theorize on what your issue is.
You are correct. It does say 443. sorry.
It times out. I tried connecting with http:// and https:// and I get the same timed out result.
Any other status things I can look at and report back to you?
I would suggest reviewing the apache2 logs and see what is in them, you could also systemctl restart apache2 to ensure it is not failing to read a conf properly.
Thank you. I will try tomorrow and get back to you
