I don’t have the files with me. But look at playwx.conf and at the buttom where it plays it for IRLP you would want to change that to something like “asterisk -xr play filename”. Then you might want to replay it 1-10 times so you not miss anything… Maybe copy it to the a voicemail box so you can call it up again if you need.
Ok I have thought about this a lot. Its great that you want a weather script to play the emergency alert. My thought is you are using the internet that might go down in bad weather. Why not just use a Weather Alert Radio with “SAME” and hard wire it in using a FOB. Then have asterisk on boot always connect to the node. Or better yet, get someone to write a SAME code for AllStarLink so you can use a Vhf radio. Then you can punch up a code and hear the weather report if you want.
David
On Sun, Dec 19, 2010 at 6:23 AM, Randy Ballard kb3hjc@gmail.com wrote:
I would be very interested on how you get this working on asterisk I use to use this on IRLP but have not been able to figure it out on Asterisk
On Sat, Dec 18, 2010 at 8:35 PM, k8khw@att.net wrote:
