Weather Script
I know there is weather scripts for irlp. But I am not having any luck for allstar. I am wondering is there anyone who has one is willing to help build one. What I am looking for just a weather alert script for the severe alerts. I don’t want a full blown weather forcast.
Any help appreciated
KB3ORS – Brian
I would be interested in that.
Dwaine
KB3ORS – Brian_______________________________________________
App_rpt-users@qrvc.com
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
I have used this script. Works well.
asterisk at home festival weather configuration
MP3 Audio directly from NOAA! Updated URLs on 12-15-06
If you are in the San Diego NOAA Office area (and maybe others, check your regional NOAA Office homepage from http://weather.gov/), you can get an audio file of the current forecast for your zone and play it directly.
For the San Diego NOAA Office area, go to http://newweb.wrh.noaa.gov/sgx/ and click on the Audio selection under Forecasts. Get the URL of the audio file for your zone from the map.
Create an announcement in wav format from: http://www.research.att.com/~ttsweb/tts/demo.php
I like the UK-Audrey voice, but try some others too.
Make something like:
latest-forecast.wav "Please wait while I download the latest forecast"
select-weatherorvmc.wav "Press 1 for voicemail press 2 for the latest weather forecast"
You will have to convert the wav files from 16000Hz to 8000Hz
and maybe speed them up a bit (135%) and reduce the volume (60%) before
you use them. Put them in /var/lib/asterisk/sounds named latest-forecast.wav and select-weatherorvmc.wav
Add something like this to your extensions.conf (maybe in the rans section) to get the latest forecast when you dial whatever extension (like 865) that you choose.
My extensions.conf for audio weather:
exten => 865,1,Answer
exten => 865,2,Playback(latest-forecast)
exten => 865,3,System(/usr/bin/curl -s [http://www.wrh.noaa.gov/sgx/data/audio/LAXSAFC42.mp3](http://www.wrh.noaa.gov/sgx/data/audio/LAXSAFC42.mp3) > /tmp/LAXSAFC42.mp3)
exten => 865,4,Wait(1)
exten => 865,5,MP3Player(/tmp/LAXSAFC42.mp3)
exten => 865,6,System(rm /tmp/LAXSAFC42.mp3 -f)
exten => 865,7,Hangup
If you have trouble, make sure you have curl installed, change the path above if necessary. find / -type f -name "curl" will find your curl executable. I'm using MP3Player instead of Playback because I don't have a sound card in the Asterisk box so mpg123 fails when it tries to use /dev/dsp. I suppose there is a way to have a dummy dev, but I don't know how. If you do use Playback instead of MP3Player, don't use the .mp3 file extension in your extensions.conf.
http://www.voip-info.org/wiki/view/asterisk+at+home+festival+weather+configuration
David
Dwaine
This is excellent but it doesn't speak to the requirement of a severe weather warning.
Try this
http://webpages.charter.net/w0anm/irlp/WxScripts.html and
http://webpages.charter.net/w0anm/irlp/scripts/WxScripts-0.9.4.noarch.rpm
You want the getWxAlert script. It calls out to NOAA and downloads an XML file formatted in the Govt's new alerting format. If you poll it every minute you'll get an update as soon as it's posted.
We have it configured on our 220 repeater such that a severe event gets play instantly and then every 10 minutes for the first hour and then 20 mins for the second hour and then 30 mins thereafter until the event is canceled.
The script can be modified to collect other info too. Amber Alerts are now using this XML format as are DHS and other Govt agencies.
Mark
your regional NOAA Office homepage from http://weather.gov/\), you can
directly.
error
You will have to convert the wav files from 16000Hz to 8000Hz and maybe
speed them up a bit (135%) and reduce the volume (60%) before you use
<http://www.voip-info.org/wiki/view/rans&gt; section) to get the latest
exten => 865,3,System(/usr/bin/curl -shttp://www.wrh.noaa.gov/sgx/data/audio/LAXSAFC42.mp3 > /tmp/LAXSAFC42.mp3)
asterisk at home festival weather configuration - VoIP-Info
David
On Thu, Dec 9, 2010 at 8:27 PM, Dwaine Garden <DwaineGarden@rogers.com > <mailto:DwaineGarden@rogers.com>> wrote:
    Dwaine
    <mailto:kb3ors@windstream.net>> wrote:
     >I know there is weather scripts for irlp. But I am not having any luck
     >for allstar. I am wondering is there anyone who has one is willing to
     >help build one. What I am looking for just a weather alert script for
     >the severe alerts. I don�t want a full blown weather forcast.
     >Any help appreciated
     >KB3ORS � Brian_______________________________________________
     >App_rpt-users mailing list
     >App_rpt-users@qrvc.com <mailto:App_rpt-users@qrvc.com>
     >http://qrvc.com/mailman/listinfo/app_rpt-users
/\/\ark Phillips
