On an arcom/repeater with allstar drving a USB-RA40, I noticed the allstar users don’t hear the next transmission, if they don’t first allow the repeater to completely drop (ie, if you transmit on RF before the allstarlink courtesey tone, none of the allstarlink users hear the transmission – none of it).
So we always say “let the repeater drop” before you transmit…
let me know a time you connect so i can replicate the problem. if I transmit on RF before i hear your allstar courtesey tone, you wont hear any of my transmission, not just the overlap, but none of it.
Calling you now from our hub… I didn’t get a response from you. I’ll leave the connection up and listen for your call back. You might hear some traffic from our side.
The result of our QSO is that there is a courtesy tone and short hang time from node 51018 when when you unkey. This almost sounds like I am hearing your repeater output except for the fact that there is no tone or hang time when I unkey.
That being the case, I have to assume the arcom controller’s port is configured as repeater or remote base. This must be changed as it is improper to send curtesy tones, hang time or IDs down AllStar links as it can cause an endless keying cycle.
I did come up with another thought since we talked. In addition to the arcom changes, please try setting hangtime = 0 and linktolink = yes in rpt.conf.
I think the echo is coming from the arcom. See if there is a way to make it full duplex without repeat. It’s a link so there should no audio path from the port’s own Rx to Tx.
Whichever Port you have Allstar connected to the RC210, make sure that Port is NOT set to Repeater Mode and also make sure you have zero hangtime programmed for it
