Is it possible to set a portable node up to where you do not have to access the router and do port forwarding where you connect it to be able to gain operability? Could a VPN be set to do tunneling to say, your home QTH and bypass this step? I have not done any VPN work in linux.
I am hoping to have a transportable node that could, for and example, Be taken to the local Emergency Operations Center and plugged into their network for internet access. Granted the IT department is not going to just let me sneak into their system to “modify” it. My thoughts are to be able to set it to where when its powered and gets its DHCP from their network, it sets up a VPN to my house cisco router and that way it would be able to pass the proper port info through the VPN to the node.
Did I explain within reason?
I appreciate all your help,
Mrs Keri Varela
Hopefully not muddying the water here. If you didn’t have a VPN going and you did plug into the EOC network and got a IP thru DHCP. Your node would work just fine, just no one would be able to connect to you. You would however be able to connect out. Do I have that right, I only ask because I’m building a transportable node myself.
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812
` That has been my experience, as long as the portable node has valid
DNS working in order to register. If not, you could (not
necessarily recommended, but it would work) edit
/etc/asterisk/iax.conf:
Hopefully not muddying the water here. If you didn't
out. Do I have that right, I only ask� because I’m building a
network for internet access.� Granted the IT
their system to “modify” it.� My thoughts are to be
proper port info through the VPN to the node.�
Mrs Keri Varela
Leon Zetekoff <> wrote:
Vpn�tunnels are great to extend your
lan.
What are you trying to do?
73 Leon wa4zlw
Sent from my Sprint Phone.
----- Reply message -----
To: <app_rpt-users@ohnosec.org>
Subject: [App_rpt-users] VPN or other option?
Date: Mon, Jan 4, 2016 8:43 PM
operability?�� Could a VPN be set to do
this step?��� I have not done any VPN work
in linux.���
Thanks for any help!!!
Keri
KB0YNA
Mesa County, Colorado RACES
To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
address and press the “Unsubscribe or edit options button”
email confirmation. If you have trouble unsubscribing, please
send a message to the list detailing the problem. wa4zlw@arrl.nethttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
Mrs Keri Varela
Vpn tunnels are great to extend your
lan.
73 Leon wa4zlw
in linux.
Keri
KB0YNA
