Tom,
OpenVPN, running in UDP-tunnel mode, is typically my VPN
solution of
choice for AllStar and it works great...
73, David KB4FXC
On Fri, 5 Aug 2016, Tom Hayward wrote:
> I'd like to hear what solutions people have come up
with for placing a
> node behind NAT where port forwarding is not
available, such as a
> cellular CGN, public wifi hotspot, public agency's
network controlled
> by an IT department, etc. My experience with this
is mostly using
> RTCMs which work fine behind NAT and can connect
out to my Asterisk
> instance running in a datacenter. I am trying to
substitute a URI and
> RPi in this scenario.
> Assuming this is a permanent, private link, I think
these options are available:
> - Set the RPi to connect to the hub on startup. If
initiating the
> connecting from inside the NAT, I think it will
allow traffic to flow
> both ways?
> - Install an OpenVPN server on the hub and OpenVPN
client on the RPi.
> Tunnel Asterisk traffic over OpenVPN.
> - Reverse SSH tunnel. Set the hub to connect to the
node on 127.0.0.2
> or whatever I bind the tunnel to.
> Has anyone tried any of these options? How did it
perform? What other
> options do I have? What am I missing?
> Tom KD7LXL
> App_rpt-users mailing list
> App_rpt-users@ohnosec.org
> [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
> To unsubscribe from this list please visit [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
and scroll down to the bottom of the page. Enter your
email address and press the “Unsubscribe or edit options
button”
> You do not need a password to unsubscribe, you can
do it via email confirmation. If you have trouble
unsubscribing, please send a message to the list
detailing the problem.
button”
You do not need a password to unsubscribe, you can do it
