Voter RTCM sometimes offline-mode but not when there is a telnet connection
Hi there,
Since November, we are trying to build a voting system.
We need some help please !
Hardware:
Supermicro Intel Atom D525 (we also tried a RaspberryPi and an other computer)
Software: Since yesterday DIAL from Alllstar-Homepage (Before we tried it with ACID)
RTCM from Micro Node, Mark, we have 4 of them and tried all of them
Garmin GPS 18x LVC, also wie tried 4 of them.
Error:
More or less often the RTCM switch in the offline mode. When there is traffic very often.
But not if at the same time there is a telnet connection from any computer to the RTCM.
We suspect a networking problem between our asterisk-server and RTCM
Network-Card is set to 10 MB / s half-duplex like in the RTCM.
From tcpdump from server to rtcm we got:
——— snip ----------
GPSTime (cli0_yy): 05/05/16 12:48:01.000000000
SysTime: 05/05/16 12:48:01.040000
DrainTime: 05/05/16 12:48:01.000
Got GPS (cli0_yy): Lat: 4857.60N, Lon: 00915.01E, Elev: 214.4
sending KEEPALIVE (GPS) packet to client cli2_bprx digest bbb4c643
GPSTime (cli2_bprx): 05/05/16 12:48:01.000000000
SysTime: 05/05/16 12:48:01.300000
DrainTime: 05/05/16 12:48:01.240
Got GPS (cli2_bprx): Lat: 4853.16N, Lon: 00912.65E, Elev: 317.2
sending KEEPALIVE (GPS) packet to client cli0_yy digest 79d9c77d
GPSTime (cli0_yy): 05/05/16 12:48:02.000000000
SysTime: 05/05/16 12:48:02.040000
DrainTime: 05/05/16 12:48:02.000
[May 512:48:03]NOTICE[6559]:chan_voter.c:3632voter_reader:Voter
lost master timing source!!
sending packet challenge 200371797 digest 7749985d password BLAH sending packet challenge 200371797 digest 7749985d password BLAH sending packet challenge 200371797 digest bbb4c643 password BLAH GPSTime (cli2_bprx): 05/05/16 12:48:18.000000000
SysTime: 05/05/16 12:48:18.320000
DrainTime: 01/01/70 01:00:00.340
– Voter client cli0_yy disconnect (timeout)
——— snip ----------
Konfiguration of the Ethernet-Card
ethtool eth0
Settings for eth0:
Supported ports: [TP]
Supported link modes: 10baseT / Half 10baseT / Full
100baseT / Half 100baseT / Full
1000baseT / Full
Supported break frame use: No
Supports auto-negotiation: Yes
Advertised link modes: Not reported
Advertised break frame use: No
Advertised auto-negotiation: No
Speed: 10Mb / s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: off
MDI-X: off (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv sample link
Does anyone have an idea what it may be ?
Why there is no problem with telnet at the same time and how can we run the system without this workaround
Rainer Bertsch
DF3SY
Is the RTCM and the server on the same Ethernet LAN at the same location?
Are you using an Ethernet switch or a hub?
If you are using a switch then why are you not running everything full duplex?
On Sat, May 21, 2016 at 3:02 PM, info@rainerbertsch.de info@rainerbertsch.de wrote:
Hi there,
Hardware:
Error:
——— snip ----------
——— snip ----------
ethtool eth0
Settings for eth0:
1000baseT / Full
Speed: 10Mb / s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
MDI-X: off (auto)
Wake-on: g
drv sample link
Rainer Bertsch
DF3SY
Hi Chuck,
thanks for the answer of my request.
Yes, RTCM and server are on the same LAN-segment. we use a switch (or better we tried several different switches) .because wie now think that there is a networkproblem.
We also tried it with 10 MB/s full duplex on both sides .
Is there any other possibility to use in the configuration of RTCM oder server ?
I tried ping tests but did not se any thin special.
Hi there,
Hardware:
Error:
——— snip ----------
——— snip ----------
ethtool eth0
Settings for eth0:
1000baseT / Full
Speed: 10Mb / s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
MDI-X: off (auto)
Wake-on: g
drv sample link
Rainer Bertsch
DF3SY
