VOTER/RTCM Firmware Version 3.20 Released
Version 3.20 is a bug fix update, with some minor feature enhancements.
Bug Fixes
Back around version 3.0, the Squelch menu, along with the Hysteresis parameter were added. The default Hysteresis is supposed to be 24, but that default value never got checked/updated/written into the EEPROM... so it always remained 0 (as that was how the EEPROM is initialized). This version checks to see if the EEPROM address is 0, and updates it to 24 if it is. If there is already a non-zero value there, it does nothing.
Resolves #3
Code analysis found that the GPS Serial Polarity (Menu 9) and GPS Baud Rate (Menu 11) didn't update when changed, requiring a reboot to take effect. This release will cause those items to update immediately when changed (you still need to save the changes though to write them into the EEPROM).
Feature Enhancement
Code analysis found that there is an un-documented "Mode 2" of DSP-BEW that makes the DSP-BEW mode twice as sensitive to energy in the passband (Mode 1 halves the amplitude of the samples before operating on them). This release updates Menu 17 to show both modes.
Resolves #24
Code Documentation/Cleanup
Voter.c was run through the ASL Clang formatter, and a significant number of formatting updates were made to bring it closer to ASL coding standards.
A significant amount of commenting was added to sections of Voter.c to better explain RSSI and DSP-BEW operation.
You can find the firmware images at:
