see
ohnosec.org
I think this one is not held.
In any case, when you download a file from ARNewsline, they have spots in the recording (marked by beeps) where you are supposed to insert an ID ...
Ken
-----Original Message-----
To: app_rpt mailing list <App_rpt-users@ohnosec.org>
Sent: Sat, Feb 9, 2013 5:53 pm
Subject: [App_rpt-users] Newsline, Again
Hi,
So, of course we can get Newsline over Echolink, but that bugs me, because the
link unkeys every so often, which is OK, but it will do so in the middle of a
word, which is annoying. So, I thought I could use playback to just play
Newsline straight through after disabling the timeout timer. Only one problem
with this: the ID's are held up until the sound file stops. Regularly scheduled
ID's don't play, and the command to force an ID doesn't play one.
So, would setting up an extension to do a playback, as documented here:
Error 404 - Page Cannot Be Found
circumvent this problem?
And, if so, would it be access via the auto patch as usual, i.e. *6 followed by
the extension?
Thanks--
Buddy Brannan, KB5ELV - Erie, PA
Phone: (814) 860-3194 or 888-75-BUDDY
On Feb 9, 2013, at 11:31 AM, David KE6UPI < > dshaw@ke6upi.com > > wrote:
> Allstarlink.org has VoIP service for 5 bucks a month. Just sign up for it.
> David
> On Fri, Feb 8, 2013 at 10:34 AM, Steve Agee < > n5zua@earthlink.net > > wrote:
> With a lot of help from another ham, I had Magic Jack working on one of my
nodes a few years ago. Unfortunately, they made some security changes and after
that point, it no longer worked. I switched to the Call Centric service and let
my Magic Jack subscription expire. This was before Allstar began offering their
service.
> N5ZUA
> ----- Original Message ----- From: 41.2 Jim
> To:
app_rpt-users@ohnosec.org
> Sent: Friday, February 08, 2013 10:59 AM
> Subject: [App_rpt-users] VOIP autopatch
> Is there any way to use my MagicJack VOIP Phone service or my Google Talk
Account(if said companies allow it) for and Asterisk autopatch? It is already
web based and should be able to be done, I'm just not smart enough to do it
> Jim Frederick KF6QBW
> IRLP Node #3911
> AllStar Node #'s
> 28839, 28842, 28843
> App_rpt-users mailing list
ohnosec.org
ohnosec.org
ohnosec.org
