Voicemail
I think I remember a thread before on this, and I am pretty sure the answer is no, but is voicemail possible on AllStar
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
electricity440@gmail.com
The question should be how can you leave voice messages… Asterisk is capable of Voicemail but the next question is it legal to record a message across the air and play it back? I dont know and I think it would be a cool idea to have an *933 to leave a voice message for the owner of the system…
Hard to say though how it would all work…
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
Main Line:1-631-686-8878 Option 1 for Loren.
Fax Line 1:1-618-551-2755
Fax Line 2:1-631-686-8892 (New Fax line)
Cell: 618-553-0806
http://www.lorentedford.com
http://www.kc9zhv.com
http://hub.kc9zhv.com
It is in a limited way.
You can drop mail into boxes directly as a phone patch and use hang-up
code when done. Pipe it to some other device/method/asterisk server for
additional use.
As I 'remember' it(?), The problem you have is having access to * and #
while in the radio channel (default).
You can wiggle around the problem with some thought.
It can be used with phones connected to the server.
...mike/kb8jnm
answer
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
In reply to Loren, I think its legal, because the simplex repeater module that you can buy has it.
The reason I asked is because I am writing a script for voicemail, and I wanted to make sure nobody has done it already.
additional use.
As I ‘remember’ it(?), The problem you have is having access to * and #
…mike/kb8jnm
answer
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
I can’t think of any reason it would be illegal, I wrote a script for IRLP a few years ago, that worked quite well, so if you get something working for Allstar, over the air, that would be awesome.
Mark
KC7DMF
“Got Root?”
How many software engineers does it take to change a light bulb?
None. It’s a hardware problem.
Unix is user friendly. It’s just very particular about who it’s friends are.
WINDOWS: Will Install Needless Data On Whole System
MICROSOFT: Most Intelligent Customers Realize Our Software Only Fools Teenagers.
A ntennas
P oorly
P laced
L acks
E ngineering
The best way to accelerate a computer running Windows is at 9.81 m/s².
“I get paid to support Windows, I use Linux to get work done.”
additional use.
…mike/kb8jnm
answer
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
It is legal as the communication you make with it.
I had it set-up years ago but don't really have a lot of use for it.
As I said, it is limited to dialing a mailbox as a phone patch and using a
hang-up code when done.(leaving a message)
But to listen to messages on a mailbox, you are out of luck on the radio
side. You need to use a phone.
I suppose you could make-shift a way around it but is that really worth it ?
...mike/kb8jnm
additional use.
...mike/kb8jnm
> answer
> KDØWHB
> Skyler Fennell
> amsatnet.info
> KDØWHB
> App_rpt-users mailing list
down
to
down
to
Skyler Fennell
amsatnet.info
KDØWHB
The script is gonna make use of the archivedir in rpt.conf.
“Got Root?”
A ntennas
P oorly
P laced
L acks
E ngineering
additional use.
…mike/kb8jnm
answer
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Voicemail is possible if you follow the directions for setting up
the voice mailboxes for Asterisk 1.4.� It will involve having
voicemail.conf file with the various options needed and something in
your dialplan in extensions.conf for it.� You will also need to make
sure app_voicemail.so isn’t set to noload in your modules.conf
file.�
Various links with information on setting it up:
It is actually pretty easy.� I don't recommend it though if you are
running a Raspberry PI with a SD Card/flash drive – it is better if
you have a HD or SDD setup to store the files.
You can even have the voicemail messages attached to an e-mail and
sent to you for listening.
73,
Stacy
KG7QIN
http://www.asteriskguru.com/tutorials/voicemaile_conf.html
http://the-asterisk-book.com/1.6/kapitel-voicemail.html
http://www.voip-info.org/wiki/view/Asterisk+cmd+VoiceMail
http://mike.eire.ca/2011/08/16/asterisk-vm-multiple-addresses/
AllStar
KD�WHB
Skyler Fennell
amsatnet.info
KD�WHB
electricity440@gmail.comApp_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
Way back when; my repeater system was run by an FF-800 controller with
mailbox/DVR option.
It was very popular with the users.
Full voice prompts with send/receive voice messages.
All over RF.
Pretty spiffy but when our little town got a cellular tower, activity/need,
died.
Cellphones got cheap and came with voicemail etc etc.
Chris
KB0WLF
-----Original Message-----
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-
bounces@ohnosec.org] On Behalf Of mike@midnighteng.com
Sent: Thursday, October 15, 2015 8:13 PM
To: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Voicemail
using a
radio
it ?
...mike/kb8jnm
-snip-
