Voice messages : Echolink callsign ?
Still about voice messages :
  When an Echolink connection occurs, if I have eannmode = 1 in
rpt.conf, I can hear the node number. But if I set eanmode=2
(which should spell the callsign), I don’t hear anything (only
“…connected to MyNode”).
  Any idea ?
  Moreover, I'd kile to playback the word "Echolink" somewhere when
an Echolink connection occurs. Is it possible to do that ?
  Thank you in advance. 73 de TK1BI
Hi,
Any clues about why Echolink would spell the calling number, but not
the callsign ?
Le 03/04/2016 14:56, Toussaint OTTAVI a
�crit�:
eannmode = 1 in rpt.conf, I can hear the node number. But if I
set eanmode=2 (which should spell the callsign), I don’t hear
anything (only “…connected to MyNode”).
A little bit more strange :
- My Echolink node is connected to a hub
- My radio node is connected to the same hub
If you connect to Echolink, you will hear a callsign, but not your callsign ! A valid callsign, but a totally unknown one !!! At the same time, on the radio node, I can just hear "connected", but no callsign at all...
Le 06/04/2016 20:38, Toussaint OTTAVI a écrit :
Any clues about why Echolink would spell the calling number, but not the callsign ?
After rebooting all, no more callsigns, nowhere...
Just a guess...
Missing sound file(s)
Conflicting settings echolink.conf and rpt.conf
When you hear some other callsign, it will announce the proxy station and not the
proxy user for non direct connects. Some proxy's don't have proper handling and
that can screw things up.
...mike/kb8jnm
Hi,
rpt.conf, I can hear the node number. But if I set eanmode=2 (which
should spell the callsign), I don't hear anything (only "..connected
to MyNode").
callsign ?
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the
bottom of the page. Enter your email address and press the "Unsubscribe or edit
options button"
problem.
I'm quite disappointed with the Echolink module. Despite my tries, I didn't manage to have it work as expected. I'm using the Android Echolink client. I do not have any control about what proxy is used. Sometimes, I hear an unknown callsign. But most of the time, I hear no callsign at all. I never heard *my* callsign ! Am I the only one having this behaviour ?
Moreover, my radio node is connected to a hub. When my Echolink node is also connected to the hub, on the radio, I can hear four quick acute bips before the "normal" bip (remotetx or linkunkeyct). I tried all the CTs, but I didn't find where those are located, and I didn't manage to remove them. When the Echolink node is disconnected from the hub, I do not hear those 4 bips. From where are they coming ? And how to remove / change them ?
Thank you in advance...
Your complaint of echolink experience should be directed at echolink.
Nobody here can control or enforce poxy's proper handling.
Your CT settings are all in rpt.conf
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
nolocallinkct=1 ; Use unlinkedct if only connected to a local node
[telemetry]
ct1=|t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
ct2=|t(660,880,150,2048)
ct3=|t(440,0,150,4096)
ct4=|t(550,0,150,2048)
ct5=|t(660,0,150,2048)
ct6=|t(880,0,150,2048)
ct7=|t(660,440,150,2048)
ct8=|t(700,1100,150,2048)
;As far as what the numbers mean,
;(0.0.10.0)
; | | | |-------amplitude
; | | |-----------duration
; | |--------------Tone 2
; |----------------Tone 1
So you might just look at your config for the node and see what CT is the 4 beeps
and look for that setting in the node stanza.
...mike/kb8jnm
this behaviour ?
change them ?
options button"
problem.
Hi,
It's not a complaint about Echolink :wink: It's a question about the Echolink channel driver for app_rpt. The purpose was to see if other people are experiencing the same problem, or if I'm the only one having this problem (which would imply a problem in my configuration)...
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
[telemetry]
That's the problem : none of them has 4 fast high frequency beeps.
I also created a "dummy" tone which is easy to recognize (400 Hz during 2 seconds). I put this to every ct I found in rpt.conf. And I still hear 4 (or 5) very fast high frequency beeps when Echolink node is conected to the hub !!!
I was wondering if there are some hidden and/or hardcoded CTs. I'll try browse the sourcecode ASAP.
Le 14/04/2016 05:22, mike@midnighteng.com a écrit :
I found this "hidden" courtesy in app_rpt.c:
{"ranger","|t(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,150,0)"}
This one is not (re-)defined in my default rpt.conf.
According to the source, this "ranger" courtesy is sent when a "RANGER" node is connected. Also, all "RANGER" node numbers should begin with "9". And my Echolink node number, choosed at random, is... 99 !
So, I found my answer :wink:
But, what on earth is a "RANGER" node ???
Then, I'll try to :
- rename my Echolink node number to something else not starting with "9"
- redefine the "ranger" ct in rpt.conf. That would allow a "special" ct when the Echolink node is connected (which is an interesting behavior)
Not sure about the four beeps, I've not gotten those and my Echolink is pretty active.
There's only one courtesy tone that isn't defined like the others...well, not quite like, anyway. I think it's the one for a remote connect for the remote end. Look for the line in the [Telemetry] stanza called
remotetx
Sorry, I said it's for the remote end transmit, but to tell you the truth, I'm never sure about that, it may be for when a remote connection is active but plays for local transmissions. Anyway, look for that.
The thing about not hearing your call when connecting through a proxy, afraid that really is a thing, yes. It must be something to do with how Echolink is sending the ID information to the node. A direct connect of course always announces the correct call. I'm fairly certain there's nothing that can be done about this.
Buddy Brannan, KB5ELV - Erie, PA
Phone: 814-860-3194
Mobile: 814-431-0962
Email: buddy@brannan.name
On Apr 14, 2016, at 6:06 AM, Toussaint OTTAVI <t.ottavi@bc-109.com> wrote:
Hi,
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
[telemetry]
To be in compliance/play nice with other All Star nodes, make your Echolink node, if you only intend it to be accessed locally, as opposed to being on a public All Star node for anyone to get directly, start with 1. For instance, attach your echolink node to node 199 and define that in your rpt.conf instead of just 99.
Phone: 814-860-3194
Then, I'll try to :
Hi,
Thank you for your comments. Our network will be local only (island-wide, <10 repeaters). It will not be connected to Allstar network for now. I missed the fact "9" was a reserved prefix for "ranger" nodes (even if I have no idea about what "ranger" is).
I'll rename the Echolink node to 199, and I think it will do the job.
73 de TK1BI
Here is a very old message about what a Ranger node is.
I don't know the whole story about them but wanted to inform those interested, what they were about.
Bob Prybyzerski
631-960-1051
W2YMM
Sent from my iPhone
Hi,
73 de TK1BI
Not start a new discussion... But 146.55 is not in the band plan here in the Pacific Northwest.
We are on 20 KHz channel spacing. 146.52, 146.54, 146.56 etc.
-----Original Message----- From: Bob Prybyzerski
Sent: Thursday, April 14, 2016 6:45 AM
To: Toussaint OTTAVI
Cc: <app_rpt-users@ohnosec.org>
Subject: Re: [App_rpt-users] Echolink : Now hearing four (unwanted) quickbips -> RANGER hidden courtesy
Sent from my iPhone
Bob Prybyzerski
631-960-1051
W2YMM
Hi,
73 de TK1BI
Understand. For more history see FCC Denies Petition Seeking to Designate Nationwide Emergency Calling Frequency
I may be missing something, but don't see a reason RANGER cant be implemented on a node unofficially. It just doesn't accomplish the goal. I like the idea, and wondered what might not have been said to justify the proposed usage. Seems to me the reasoning was sound.
Bob
kk6ecm
Sent from iPad
ohnosec.org - ohnosec Resources and Information.
Sent from my iPhone
Bob Prybyzerski
631-960-1051
W2YMM
Hi,
73 de TK1BI
