Pierre,
There is not much stopping you from experimenting on your own
right now.
It helps if you are familiar with asterisk commands and at least
bash scripts. AGI scripting a plus, but you can figure that out,
it’s all well documented.
This has been done with asterisk for at least 6-7 years.
I'm sure those folks at nervittles.com have some updated packages
now-a-days.
A quick look shows so there
is your start. Adapt from that.
As far as not triggering it outside of your intended system,
that can be accomplished using app_rpt’s event management system,
a quick look at 'last keyed node' will give you the data to
evaluate if the node that gave the attention keyword is one you
want to allow the flow of voice commands and can/will prevent
network falsifying.
The major hick-ups that I had was from all the dev's and hack's
kept overloading the free use of dev tools and google and MS kept
changing the criteria for how it worked. The more that were
playing, the faster the changes came in. Much like voice.google
has finally been shut down as a open interface in the end after
frequent changes to eliminate those that were using it for
unintended purposes. Those changes were a bit slower since google
had contracts for devices that worked from them. The same will
probably happen to the voice assistant boxes in the end. I have
seen so many hacks for them on the internet now. Enjoy and learn
from the freebie while you can.
Personally, now, I don't have a interest in any of them that rely
on external networks to do the task. But a STT/TTS engine run on a
local server is not a uncomplicated task if it is to be accurate.
And that’s why google, MS, IBM and a few others have this pretty
much wrapped up for now, but not forever. They did spend about 5+
years developing this and there was quite a battle over the talent
to do it between MS and Google.
Anyway, I see you have the bug... really, you should go for it !
It is fun. The more that are playing, the better the chances
someone comes up with something really useful, not just novel.
…mike/kb8jnm
http://nerdvittles.com/?p=21703
On 1/6/2019 11:08 AM, Pierre Martel
wrote:
Thanks William for the feedback.
I find your implementation on the IRLP controler to be a
piece of art…
Can I ask you what method did you used for the irlp
controler? was it the original irlp software or did you used
the irlp driver in app_rpt?
did you implement a way to prevent the AI to respond to
request sent by a networked audio feed?
I am hyper excited by this and cant wait to test this.
Pierre
VE2PF
Le dim. 6 janv. 2019 à 08:53, William Franzin
wfranzin@gmail.com a écrit :
Good morning,
We're also keen AllStarLink/app_rpt
users/experimenters here in Winnipeg and Dan mentioned
a discussion about the work I did on here, so thought
I’d fill in the blanks. Also joined this list.
I started with Google Assistant and Amazon Alexa
and really just wanted to control devices using voice,
the “what’s the weather” was just an added bonus, but
all that requires internet.
I also liked the speed of running the assistant
code in real-time, as you speak that’s actually a
stream to Google/Amazon so the results you get are
immediate vs rec/upload/download/play.
For the majority of ham radio actual "needs" in
voice control the Picovoice Rhino project
speech-to-intent would do a great job. If you haven’t
check it out: https://github.com/Picovoice
Also watch their video: https://www.youtube.com/watch?v=WadKhfLyqTQ
which I think is exactly what we’d want from a ham
radio setup. Wakework “Hey Repeater” “Turn on …”.
All of that great capability runs entirely on the
device/server/reflector, no internet or web service
call to Google/Amazon is needed. And it produces this
simple output too:
"type": "espresso" ,
"size": "small" ,
"numberOfShots": "2" ,
"sugar": "a lot" ,
"milk": "some"
We should do this, my 2010 Ford Escape has had
Microsoft Sync voice control and it’s nothing new.
Everything has voice control these days, and it
actually works really well now.
The only challenge in ham is we need to come up
with some standard commands so if you’re visiting here
you know the repeater has this capability and how to
work it.
If anything I'm just glad the videos I posted a
while back got this topic going again. Certainly not
the first person to poke around with voice - it’s just
really easy now to implement this.
Thanks to all the folks working on
AllStarLink/app_rpt too. I just built a firmware image
with AllStarLink for a Sierra Radio Systems CommServer
board and it was apt-get-easy
–let-me-drink-my-coffee-while-the-hard-work-gets-done
William VE4VR
[http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
and scroll down to the bottom of the page. Enter your email
address and press the “Unsubscribe or edit options button”
email confirmation. If you have trouble unsubscribing, please
send a message to the list detailing the problem.
