virtual machine.
Anyone here ever used a virtual machine engine like virtualbox to run a node or many node from a computer?
I ask cause at my club repeater we have a computer that is pretty good (dual 2.8 ghz cpu with 4 gig ram running windows 7
and we have some software running on it.
And i really cant switch this computer to linux.
so if I run the acid distro from a virtual machine and link the USB uri to that machine (wich is not too simple but doable) I think I would be able to run the app_rpt software while keeping the win 7 machine running smooth…
so anyone did that before??
I’ve attempted it using the ACID distro under KVM, but it failed miserably. I couldn’t get the URI to communicate to the virtual machine, but it may have been my own error, so YMMV :slight_smile:
If you try it out and it works let us know as I would still like to consider virtualizing mine as well…
Stephen
K1LNX
Stephen Brown - ARS K1LNX
Johnson City, TN EM86
http://www.k1lnx.net
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
SIP: k1lnx@k1lnx.net
Wow… actually expecting USB to work on a VM??
As Im sure you found… NFL (Not Likely… the ‘F’ is silent :slight_smile: ).
There just are some things that virtualization is virutally useless for…
But for some applications, it does have some virtue…
JIM WB6NIL
Date: Sat, 28 May 2011 06:54:37 -0400
To: App_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] virtual machine.
Stephen
K1LNX
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
<-- Hi Jim and all; I have a VM on top of an old Asterisk box (host O/S is running CENTOS 5.3; Sun Virtual Box as the VM Engine and then XP as a guest). I am running a D-STAR client in the XP VM, where I pass a USB sound fob from the host machine to the VM.
That works.... but.... I do hear some clicking in the audio, which I have not bothered to investigate - it could be a resource issue or something else - but the fact that I was able to pass a USB device from the host machine to the guest VM should provide you with some confidence to experiment further!
Cheers,
Ramesh.
On 28/05/2011 7:51 AM, Jim Duuuude wrote:
Wow... *actually* expecting USB to work on a VM??
As Im sure you found... NFL (Not Likely... the 'F' is silent :slight_smile: ).
There just are some things that virtualization is virutally useless for..
But for some applications, it does have some virtue..
I haven't tried it with Asterisk or on a URI, but I have had VMs running USB devices before, the most demanding example I can think of is a Funcube Dongle (SDR front end at 96 kHz sample rate) running inside a VM, and that worked perfectly. I can't see why a URI wouldn't work on the right VM platform. For the record, I was using VMware Fusion on a Mac as the VM host.
73 de VK3JED / VK3IRL
http://vkradio.com
