Very strange problem with DIAL + USB URIs.
Hi,
I have a very strange problem with DIAL + USB URIs.
I get choppy audio after a couple of days or maybe several hours of constant use.
Restarting asterisk or even the PC wont solve the problem.
The problem only goes away if I connect the URI to another USB or shut down the PC for several hours.
Maybe some temperature problem on the USB card??
I’m using a standard PC (i5 + 8GB) with 2 USB URIs.
To test the problem I connected a tone generator to the URIs.
These are some examples of the saved audio files in asterisk:
Normal
After several hours
after one day
Some advice would be very appreciated
Thanks in advance
Best Regards
John
Bob
K6ECM
On Apr 17, 2018, at 7:05 AM, John Locke jldharma@gmail.com wrote:
Hi,
Normal
<image.png>
After several hours
<image.png>
<image.png>
<image.png>
after one day
<image.png>
<image.png>
Thanks in advance
Best Regards
John
I am testing with 3 o 4 different PC models with the same problem, all new models…
Some of them can run for 2 days without the problem, some get the audio chopped in just a few hours.
I’m using usbradio. Do you think that the simpleusb can work better?
I have no experience with simpleusb, and I’m willing to pay some consulting hours to solve this problem…
Thanks in advance
Best Regards
John
On Tue, Apr 17, 2018 at 3:48 PM, Bob Pyke k6ecm1@gmail.com wrote:
From my experience, it’s not the URI; more likely an issue with the computer USB controller in the PC. …Spent a bit of time finding that one.
Bob
K6ECM
Hi,
Normal
<image.png>
After several hours
<image.png>
<image.png>
<image.png>
after one day
<image.png>
<image.png>
Thanks in advance
Best Regards
John
Hi John,
When you start to have the audio problems, try running the dahdi_test
program from a bash prompt. Here are sample numbers from a Raspberry Pi
3B plus, with turbo mode enabled:
[root@kb4fxc-portable asterisk]# dahdi_test -c 100
Opened pseudo dahdi interface, measuring accuracy...
99.992% 99.989% 99.996% 99.995% 99.996% 99.996% 99.993% 99.995%
99.994% 99.992% 99.995% 99.995% 99.995% 99.996% 99.993% 99.995%
99.995% 99.995% 99.993% 99.994% 99.994% 99.995% 99.994% 99.994%
99.994% 99.993% 99.994% 99.994% 99.994% 99.994% 99.994% 99.994%
99.994% 99.993% 99.994% 99.993% 99.995% 99.995% 99.995% 99.996%
99.995% 99.995% 99.995% 99.995% 99.995% 99.996% 99.995% 99.994%
99.995% 99.994% 99.995% 99.995% 99.995% 99.995% 99.995% 99.995%
99.996% 99.994% 99.995% 99.995% 99.995% 99.995% 99.995% 99.995%
99.995% 99.994% 99.995% 99.995% 99.995% 99.995% 99.996% 99.995%
99.995% 99.994% 99.995% 99.995% 99.995% 99.996% 99.995% 99.995%
99.995% 99.994% 99.995% 99.995% 99.995% 99.995% 99.996% 99.994%
99.995% 99.994% 99.995% 99.996% 99.994% 99.995% 99.995% 99.995%
99.995% 99.993%
--- Results after 98 passes ---
Best: 99.996% -- Worst: 99.989% -- Average: 99.994621%
Cummulative Accuracy (not per pass): 99.995
73, David KB4FXC
models...
I'm using usbradio. Do you think that the simpleusb can work better?
I have no experience with simpleusb, and I'm willing to pay some consulting
hours to solve this problem...
Thanks in advance
Best Regards
John
> computer USB controller in the PC. ...Spent a bit of time finding that one.
> Thanks,
> Bob
> K6ECM
> 73
> On Apr 17, 2018, at 7:05 AM, John Locke <jldharma@gmail.com> wrote:
> Hi,
> constant use.
> I'm using a standard PC (i5 + 8GB) with 2 USB URIs.
> Normal
> <image.png>
> After several hours
> <image.png>
> <image.png>
> <image.png>
> after one day
> <image.png>
> <image.png>
> Thanks in advance
> Best Regards
> John
> App_rpt-users mailing list
> App_rpt-users@lists.allstarlink.org
> http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users
> To unsubscribe from this list please visit http://lists.allstarlink.org/
> cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of
> the page. Enter your email address and press the "Unsubscribe or edit
> options button"
> You do not need a password to unsubscribe, you can do it via email
> confirmation. If you have trouble unsubscribing, please send a message to
> the list detailing the problem.
> options button"
