Version 0.10
Date: 2009/11/23 Mon AM 10:17:23 PST
To: app_rpt <App_rpt-users@qrvc.com>
Subject: [App_rpt-users] Version 0.10
Just ran astupd.sh on my node and got:
You have ACID version: 0.9 and the version on http://dl.allstarlink.org is: 0.10
Fatal error: astupd.sh cannot be used, you must re-install ACID to update this system.
Does 0.10 address any of the audio dropout problems recently discussed? Dropouts are a recurring problem on my nodes as well. Hate to do a complete reinstall, but willing if there's a reason.
Thanks!
John / WB5NFC
No need to upgrade just yet.
There have been no changes to app_rpt or chan_usbradio for ACID 0.10. ACID 0.10.The change from 0.9 to 0.10 was only
because of some install script changes to support servers with large amounts of memory on them.
Regarding audio dropouts:
Some people have reported issues with audio dropouts, but I have not seen this on any system I installed on node 2011 so I don't really know how real this problem is.
Even if I did have a system exhibiting this problem, it would have to be investigated by the authors of the usb channel driver Jim Dixon, WB6NIL and Steve Henke, W9SH as they wrote the code and know where to look for problems.
Steve
WA6ZFT
Steve
WA6ZFT
Thanks!
John / WB5NFC
Some people have reported issues with audio dropouts, but I have not seen this on any system I installed on node 2011 so I don't really know how real this problem is. Even if I did have a system exhibiting this problem, it would have to be investigated by the authors of the usb channel driver Jim Dixon, WB6NIL and Steve Henke, W9SH as they wrote the code and know where to look for problems.
Steve
WA6ZFT
Steve
WA6ZFT
Hi Steve..
I've got ACID instaled & running on two much higher end systems now..
An Intel based Q6700 quadcore @3.2Ghz (overclocked) also tried it at stock 2.66Ghz speed :slight_smile:
And an AMD athlon64 running @2.8Ghz
Both systems still experience some audio dropouts...
I think it's possible that others have this issue but are not reporting it.
They are relatively infrequent (3-4 small pops per minute avg.) and do not keep you from running a usable system.
I've been testing in such a way that really makes the droputs show up as well..
On a normal system the dropouts are not going to be as obvious.
My test arrangement is this:
1. No timeout timer on repeater TX.
2. PL endcode from usbradio to transmitter.
3. CWID set to ID every 60 seconds
4. Beaconing turned on (so that cwid will go off on its own every minute.
5. issue "radio key" command to key radio and send PL
Audio plugged into a stereo system with good speakers and listening to the PL tone + CWID every minute for several days while I work on other things in the shop..
Yes people think I'm nuts for listening to that every minute..
Doesn't bother me a bit :wink:
I need to program someone else's callsign into it so people won't think I have Morse vanity issues.
I'll be trying out these other kernel options and Daves patches and report back with results as soon as I can get my kernel compiling lack of skills to cooperate
If you are relying on (usbradio) to provide pl encode then the dropouts can be an issue.
And you can hear them on the voice/cwid of the repeater.
On the faster systems my experience so far is that the dropouts sound 'faster'.
I'll provide audio samples if needed.
I'll be back with much better data than I've provided so far on this issue.
This is awesome and I am having a lot of fun with it.
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Thanks!
John / WB5NFC
Steve
WA6ZFT
Steve
WA6ZFT
Hi Steve..
Just found the complete list of commands in the source code (app_rpt.c)
It looks like *100 and *101 might be what I need.
Not sure if this is for the repeater or serially connected remote base.
Have a feeling it's not for the repeater.
