V2 beta 6 Node 53666 not showing on stat.allstarlink.org
I recently updated a Node 53666 from V1.01 to.V2 beta 6. Almost everything is working, it can accept connection, it is showing green in Allstarlink.org. The only 2 things not working is the Bubble and it is not showing in stat.allstarlink.org
I checked the reporting stanza in rpt.conf and it looks alright
Are there any more stanza or script that involves reporting to stat.allstralink.org
Anthony
The stats server works from these lines in your rpt.conf
Make sure only the correct ones are enabled and uncommented
; ** For ACID and Debian ***
statpost_program = /usr/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
statpost_url = http://stats.allstarlink.org/uhandler.php ; Status updates
Thanks Mike for the quick reply
I need to edit the reporting stanza then
On V2 the reporting stanza is this
;*** Status Reporting ***
; Comment the following statpost line stop to reporting of the status of your node to stats.allstarlink.org
statpost_url = http://stats.allstarlink.org/uhandler ; Status updates
And the one you posted is the same on ASL V 1, so can I replace the ASL V2 beta6 with the one on V1?
*** For ACID and Debian ***
Well, actuall, you probably should run with the newer stat posting.
I had forgot about the change. Most of my 5 systems are running 1.01
But you could test that older to see if any change if it’s still not working.
Then I would really be confused LOL
You should be running this one. Just be sure it is not commented out.
I see that 53666 is showing stats now.
Could you share what you found for a solution that it might help others ?
Oh yeah, just did it last night. I replaced the reporting script back to V2 and rearrange the rpt.conf
Before the 2 privatenodes stanza was beside the reporting stanza.( does this matter? And remove a bunch of semicolon ;;;;;;;;;;;; between reporting stanza and Nodes stanza) And the regular Node was in the first row then followed by the privatenodes 1998 and 1999
I just switch it and made the regular Node be beside the reporting stanza. And it worked
Sorry for my explanation
