Hi:
I want to try using my Kenwood TH-F6A HT in 1200 baud mode with a modified fob, and usbradio with DSP detection of PL tone, as I think this will sound a lot better than any of the portable 818-based node modules out there, I.E. SHARI, clear node, etc.
I have a fob that I’m pretty sure will work. It was modified such that DC voltage will pull up cos for simpleusb, but for my TH-F6A, that won’t work. The rest of the setup should be fine so long as DSP can detect and filter out my CTCSS. I can transmit just fine with this radio using simpleusb even though cos doesn’t quite work right, because the bias isn’t right. It works fine with a Baofeng HT or similar, but that won’t give me flat audio.
I don’t think my problem is with the hardware.
However, I can’t seem to get chan_usbradio.so to work as I expect.
Here is how things are configured in /etc/asterisk/usbradio.conf.
[general]
[usb_508423]
; 0 = no (default)
; 1 = yes
hdwtype = 0 ; Leave this set to 0 for USB sound fobs modified using
rxboost = 1 ; 0 - 20db attenuator inserted
; 1 - 20db attenuator removed
; Set to 1 for additonal gain if using a low-level receiver output
rxctcssrelax = 1 ; reduce talkoff from radios w/o CTCSS TX HPF
rxsqhyst = 3000 ; Setting Squelch Hysteresis
; 3000 is the default amount.
; An amount of 500 seems good.
; Then set the squelch to the highest number revealed when doing a “radio
; tune rxsquelch” - running the command multiple (like 20) times in a row.
; http://allstarnode.com/wiki/lib/exe/fetch.php?media=asterisk-notes-wj8g.pdf
txctcssdefault = 100.0 ; default TX CTCSS frequency, any frequency permitted
rxctcssfreqs = 100.0,91.5 ; RX CTCSS frequencies list in floating point. must be in table
txctcssfreqs = 100.0,91.5 ; TX CTCSS frequencies list. any frequency permitted. will follow RX CTCSS frequency
rxctcssoverride = 0 ; Set to 1 to start out in carrier squelch mode
carrierfrom = dsp ; no,usb,usbinvert,dsp,vox
; usb - from the COR line on the USB sound fob (Active high)
; usbinvert - from the inverted COR line on the USB sound fob (Active low)
; dsp - from RX noise using DSP techniques
; vox - voice activated from RX audio
ctcssfrom = usbinvert ; no,usb,usbinvert,dsp
; no - no CTCSS decoding, system will be carrier squelch
; usb - from the CTCSS line on the USB sound fob (Active high)
; usbinvert - from the inverted CTCSS line on the USB sound fob (Active low)
; dsp - CTCSS decoding using RX audio in DSP.
; rxdemod option must be set to flat for this to work.
rxdemod = flat ; input type from radio: no,speaker,flat
; flat - Use RX audio from discriminator (before de-emphasis)
rxsquelchdelay = 100 ; delayline in ms carrier squelch tail eliminator
rxondelay = 0 ; Number of 20mSec intervals following the release of PTT.
; Uncomment and/or adjust for simplex nodes to eliminate “Ping Ponging”
; or “Relay Racing”. A positive value here will instruct the usbradio
; driver to ignore the COR line for a specified number of 20mSec
; intervals following the release of PTT. Use this ONLY on simplex
; nodes, and leave commented out for repeaters or other full duplex nodes.
txboost = 0 ; Add transmitter audio gain boost: 0,1
txprelim = yes ; Audio processing on left output channel: no,yes
; no - Audio is not pre-emphasized and limited.
; Suitable for use on a microphone input
; yes - Audio is pre-emphasized and limited.
; Suitable for direct connection to an FM modulator
txlimonly = yes ; Audio limiting with no pre-emphasis on output channel: no,yes
; no - Audio is not limited.
; yes - Audio is limited.
; Suitable for transmitters with no limiting but with pre-emphasis.
txtoctype = notone ; Transmit tone control type: no,phase,notone
; phase - encode CTCSS and reverse phase
; AKA (“reverse burst”) before unkeying TX
; notone - encode CTCSS and stop sending tone before unkeying TX
; AKA (“chicken burst”)
txmixa = composite ; Left channel output: no,voice,tone,composite,auxvoice
; no - Do not output anything
; voice - output voice only
; tone - CTCSS tone only
; composite - voice and tone
; auxvoice - auxiliary voice output at headphone level for monitoring
txmixb = no ; Right channel output: no,voice,tone,composite, auxvoice
invertptt = 0 ; Invert PTT: 0,1
; 0 - ground to transmit
; 1 - open to transmit
duplex = 1 ; Duplex 0,1
; 0 - half duplex
; 1 - full duplex
duplex3 = 0 ; duplex 3 gain setting (0 to disable) ???
In /etc/asterisk/modules.conf,
load => chan_usbradio.so
and in /etc/asterisk/rpt.conf in the stanza for my node:
rxchannel = Radio/usb_508423
However, when I then load Asterisk, it usually breaks at importing from /etc/asterisk/usbradio.conf. Sometimes, it gets as far as saying something like chan_usbradio.so wasn’t stuck after all, then Asterisk usually crashes.'Is anyone still using this module? Does it even work anymore?
It seems to create an empty configuration file for usradio_tune_usb_508423.conf. Just for fun, I tried copying my simpleusb_tune_usb_508423.conf to usbradio_usb_tune_508423.conf, not knowing if the same parameters are shared, since I haven’t actually seen a working example, but it didn’t seem to help.
I miss the sound of my Motorola Radius (currently in storage) and thought this would be a pretty good substitute if I could get it working.
I am trying this on a rPi 3B Plus running the ASL 1.01 image.
Thanks and 73
de
KE4DYI
