Hi all
I just set up ASL3 with my AIOC adapter today but its not at 100% operation yet. I have checked the network and pinged the network and all seems well.
When I connect to a node it tells mme Im connected and the bubble chart backs this up.But Im getting patchy recieve audio and no Tx audio as far as Im aware).
Any advice greatly appreciated.
73 Damien 2E0EUI
Hello,
As per my knowledge, Ensure your ASL3 and AIOC adapter are properly configured for audio input and output. Check network stability despite normal pings. Verify node connection settings in ASL3. Double-check physical connections and update software if needed.
I hope this will help you.
Respected community member
Check rpt.conf and try carrierfrom=usbinvert and ctcssfrom=no
Remember the audio is connected with the sound knob of the radio you are using with the AIOC. Mine works just a bit higher than halfway. something to check perhaps?
