Here goes, here's the entire rpt.conf, no secrets within!
I'm preparing to slap my forehead when you point out what mistake Ive made!!
(I had to reduce the number of characters to the max limit of the forum so cur out some of the commented out parts......)
;******** Template-tized rpt.conf ********
[general]
node_lookup_method = both ;method used to lookup nodes
;both = dns lookup first, followed by external file (default)
;dns = dns lookup only
;file = external file lookup only
[nodes]
648490 = radio@127.0.0.1/648490,NONE
[node-main](!)
;;; rxchannel ;;;
rxchannel = Radio/648490 ; No radio (hub)
duplex = 4 ; 0 = Half duplex with no telemetry tones or hang time.
; 1 = Half duplex with telemetry tones and hang time. Do not repeat audio.
; This mode is preferred when interfacing a repeater.
linktolink = no ; disables forcing physical half-duplex operation of main repeater while
; still keeping half-duplex semantics (optional)
linkmongain = -22 ; Link Monitor Gain adjusts the audio level of monitored nodes when a signal from another node or the local receiver is received.
; If linkmongain is set to a negative number the monitored audio will decrease by the set amount in db.
; If linkmongain set to a positive number monitored audio will increase by the set amount in db.
; The value of linkmongain is in db. The default value is 0 db.
erxgain = -3 ; EchoLink receive gain adjustment
; Note: Gain is in db-volts (20logVI/VO)
etxgain = 3 ; EchoLink transmit gain adjustment
;eannmode = 1 ; 1 = Say only node number on EchoLink connects (default = 1)
; 2 = say phonetic call sign only on EchoLink connects
; 3 = say phonetic call sign and node number on EchoLink connects
;echolinkdefault = 2 ; 0 = Telemetry output off
; 1 = Telemetry output on
; 2 = Timed telemetry output on command execution and for a short time thereafter
; 3 = Follow local telemetry mode
;echolinkdynamic = 1 ; 0 = Disallow users to change current EchoLink telemetry setting with a COP command
; 1 = Allow users to change the setting with a COP command
controlstates = controlstates ; System control state stanza
events = events ; Events Management
functions = functions ; Repeater Function stanza
link_functions = functions ; Link Function stanza
morse = morse ; Morse stanza
phone_functions = functions ; Phone Function stanza
scheduler = schedule ; Scheduler stanza
telemetry = telemetry ; Telemetry stanza
wait_times = wait-times ; Wait times stanza
macro = macro648490
;inxlat = *,#,0123456789ABCD,Y ; The Y is for dialtone on function, a la CACTUS
; https://wiki.allstarlink.org/wiki/Rpt.conf#inxlat.3D
context = radio ; dialing context for phone
callerid = "Repeater" <0000000000> ; callerid for phone calls
accountcode = RADIO ; account code (optional)
hangtime = 5000 ; squelch tail hang time (in ms) (optional, default 5 seconds, 5000 ms)
althangtime = 5000 ; longer squelch tail
totime = 360000 ; transmit time-out time (in ms) (optional, default 3 minutes 180000 ms)
idrecording = |iGB3VS F ; id recording or morse string
idtalkover = |iGB3VS ; Talkover ID (optional) default is none
idtime = 540000 ; id interval time (in ms) (optional) Default 5 minutes (300000 ms)
politeid = 30000 ; time in milliseconds before ID timer expires to try and ID in the tail. (optional, default 30000)
max value possible)
unlinkedct = ct1 ; Send a this courtesy tone when the user unkeys if the node is not connected to any other nodes. (optional, default is none)
remotect = ct4 ; remote linked courtesy tone (indicates a remote is in the list of links)
linkunkeyct = ct8 ; sent when a transmission received over the link unkeys
;nolocallinkct = 0 ; Send unlinkedct instead if another local node is connected to this node (hosted on the same PC).
;connpgm = yourconnectprogram ; Disabled. Execute a program you specify on connect. (default)
; passes 2 command line arguments to your program:
; 1. node number in this stanza (us)
; 2. node number being connected to us (them)
;discpgm = yourdisconnectprogram ; Disabled. Execute a program you specify on disconnect. (default)
; 2. node number being disconnected from us (them)
;lnkactenable = 0 ; Set to 1 to enable the link activity timer. Applicable to standard nodes only.
;lnkacttime = 1800 ; Link activity timer time in seconds.
;lnkactmacro = *52 ; Function to execute when link activity timer expires.
;lnkacttimerwarn = 30seconds ; Message to play when the link activity timer has 30 seconds left.
;nounkeyct = 0 ; Set to a 1 to eliminate courtesy tones and associated delays.
holdofftelem = 1 ; Hold off all telemetry when signal is present on receiver or from connected nodes
; except when an ID needs to be done and there is a signal coming from a connected node.
telemnomdb = -3 ; Telemetry Nominal Amplitude reference in dB
telemduckdb = -15 ; Telemetry Ducking in dB when local or link voice TX in progress
telemdefault = 2 ; 0 = telemetry output off
; 1 = telemetry output on (default = 1)
; 2 = timed telemetry output on command execution and for a short time thereafter.
telemdynamic = yes ; yes = disallow users to change the local telemetry setting with a COP command
; 1 = Allow users to change the setting with a COP command. (default = 1)
beaconing = 0 ; Send ID regardless of repeater activity (Required in the UK, but probably illegal in the US)
parrotmode = 3 ; 0 = Parrot Off (default = 0)
; 1 = Parrot On Command
; 2 = Parrot Always
; 3 = Parrot Once by Command
parrottime = 1000 ; Set the amount of time in milliseconds
; to wait before parroting what was received
;rxnotch=1065,40 ; (Optional) Notch a particular frequency for a specified
; b/w. app_rpt must have been compiled with
; the notch option
startup_macro = *81343679 ; Best use in your node stanza (below) when more than one node
nodenames = /etc/asterisk/nodenames ; Point to alternate nodename sound directory
;aprstt = general ; To enable APRStt, set this value to the stanza to use in gps.conf
; module app_gps.so will need to be enabled
;statpost_url = http://stats.allstarlink.org/uhandler ; Status updates
;;; End of node-main template
[functions]
;;;;;;;;;;;;;;;;;;; functions stanza ;;;;;;;;;;;;;;;;;;;
; Prefix Functions
; *1 Disconnect Link
; *2 Monitor Link
; *3 Connect Link
; *4 Command Mode
; *5 Macros
; *6 User Functions
; *7 Connection Status/Functions
; *8 User Functions
; *9 User Functions
; *0 User Functions
; *A User Functions
; *B User Functions
; *C User Functions
; *D User Functions
;;;;;; Mandatory Command Codes ;;;;;
1 = ilink,1 ; Disconnect specified link
2 = ilink,2 ; Connect specified link -- monitor only
3 = ilink,3 ; Connect specified link -- transceive
4 = ilink,4 ; Enter command mode on specified link
70 = ilink,5 ; System status
;99 = cop,6 ; PTT (phone mode only)
;;;;; Macro Commands ;;;;;
5 = macro
;;;;; Autopatch Commands ;;;;;
; Note, This may be a good place for other 2 digit frequently used commands
;61 = autopatchup,noct = 1,farenddisconnect = 1,dialtime = 20000 ; Autopatch up
;62 = autopatchdn ; Autopatch down
; autopatchup can optionally take comma delimited setting=value pairs:
; context = string ; Override default context with "string"
; dialtime = ms ; Specify the max number of milliseconds between phone number digits (1000 milliseconds = 1 second)
; farenddisconnect = 1 ; Automatically disconnect when called party hangs up
; noct = 1 ; Don't send repeater courtesy tone during autopatch calls
; quiet = 1 ; Don't send dial tone, or connect messages. Do not send patch down message when called party hangs up
; Example: 123=autopatchup,dialtime=20000,noct=1,farenddisconnect=1
;;;;; Status Commands ;;;;;
; 1 - Force ID (global)
; 2 - Give Time of Day (global)
; 3 - Give software Version (global)
; 4 - Give GPS location info
; 5 - Last (DTMF) user
; 11 - Force ID (local only)
; 12 - Give Time of Day (local only)
721 = status,1 ; Force ID (global)
722 = status,2 ; Give Time of Day (global)
723 = status,3 ; Give software Version (global)
724 = status,4 ; Give GPS location info
725 = status,5 ; Last (DTMF) user
711 = status,11 ; Force ID (local only)
712 = status,12 ; Give Time of Day (local only)
;;;;; Link Commands ;;;;;
; 1 - Disconnect specified link
; 2 - Connect specified link -- monitor only
; 3 - Connect specified link -- transceive
; 4 - Enter command mode on specified link
; 5 - System status
; 6 - Disconnect all links
; 7 - Last Node to Key Up
; 8 - Connect specified link -- local monitor only
; 9 - Send Text Message (9,<destnodeno or 0 (for all)>,Message Text, etc.
; 10 - Disconnect all RANGER links (except permalinks)
; 11 - Disconnect a previously permanently connected link
; 12 - Permanently connect specified link -- monitor only
; 13 - Permanently connect specified link -- transceive
; 15 - Full system status (all nodes)
; 16 - Reconnect links disconnected with "disconnect all links"
; 17 - MDC test (for diag purposes)
; 18 - Permanently connect specified link -- local monitor only
;;;;; ilink commands ;;;;;
; commands 1 through 5 are defined in the Mandatory Command section
806 = ilink,6 ; Disconnect all links
; 807 = ilink,7 ; Last Node to Key Up
; 808 = ilink,8 ; Connect specified link -- local monitor only
; 809 = ilink,9,1999,"Testing" ; would send a text message to node 1999 replace 1999 with 0 for all connected nodes
; 810 = ilink,10 ; Disconnect all RANGER links (except permalinks)
811 = ilink,11 ; Disconnect a previously permanently connected link
; 812 = ilink,12 ; Permanently connect specified link -- monitor only
813 = ilink,13 ; Permanently connect specified link -- transceive
; 815 = ilink,15 ; Full system status (all nodes)
; 816 = ilink,16 ; Reconnect links disconnected with "disconnect all links"
; 817 = ilink,17 ; MDC test (for diag purposes)
; 818 = ilink,18 ; Permanently connect specified link -- local monitor only
;;;;; Control operator (cop) functions. ;;;;;
;Change these to something other than these codes listed below!
901 = cop,1 ; System warm boot
902 = cop,2 ; System enable
903 = cop,3 ; System disable
;904 = cop,4 ; Test tone on/off (toggle)
;905 = cop,5 ; Dump system variables on console (debug use only)
;907 = cop,7 ; Time out timer enable
;908 = cop,8 ; Time out timer disable
;909 = cop,9 ; Autopatch enable
;910 = cop,10 ; Autopatch disable
;911 = cop,11 ; User linking functions enable
;912 = cop,12 ; User linking functions disable
;913 = cop,13 ; Query system control state
;914 = cop,14 ; Set system control state
;915 = cop,15 ; Scheduler enable
;916 = cop,16 ; Scheduler disable
;917 = cop,17 ; User functions enable (time, id, etc)
;918 = cop,18 ; User functions disable
;919 = cop,19 ; Select alternate hang time (althangtime)
;920 = cop,20 ; Select standard hangtime (hangtime)
;921 = cop,21 ; Enable Parrot Mode
;922 = cop,22 ; Disable Parrot Mode
;923 = cop,23 ; Birdbath (Current Parrot Cleanup/Flush)
924 = cop,24 ; Flush all telemetry
;925 = cop,25 ; Query last node un-keyed
;926 = cop,26 ; Query all nodes keyed/unkeyed
;930 = cop,30 ; Recall Memory Setting in attached transceiver
;931 = cop,31 ; Channel Selector for parallel programmed transceiver
932 = cop,32 ; Touchtone pad test: command + Digit string + # to playback all digits pressed
;933 = cop,33 ; Local Telemetry Output Enable
;934 = cop,34 ; Local Telemetry Output Disable
;935 = cop,35 ; Local Telemetry Output on Demand
;936 = cop,36 ; Foreign Link Local Output Path Enable
;937 = cop,37 ; Foreign Link Local Output Path Disable
;938 = cop,38 ; Foreign Link Local Output Path Follows Local Telemetry
;939 = cop,39 ; Foreign Link Local Output Path on Demand
;942 = cop,42 ; EchoLink announce node # only
;943 = cop,43 ; EchoLink announce node Callsign only
;944 = cop,44 ; EchoLink announce node # & Callsign
;945 = cop,45 ; Link Activity timer enable
;945 = cop,46 ; Link Activity timer disable
;947 = cop,47 ; Reset "Link Config Changed" Flag
;948 = cop,48 ; Send Page Tone (Tone specs separated by parenthesis)
; 949 = cop,49 ; Disable incoming connections (control state noice)
; 950 = cop,50 ; Enable incoming connections (control state noicd)
; 951 = cop,51 ; Enable sleep mode
; 952 = cop,52 ; Disable sleep mode
; 953 = cop,53 ; Wake up from sleep
; 954 = cop,54 ; Go to sleep
; 955 = cop,55 ; Parrot Once if parrot mode is disabled
; 956 = cop,56 ; RX CTCSS Enable
; 957 = cop,57 ; RX CTCSS Disable
; 958 = cop,58 ; TX CTCSS On Input only Enable
; 959 = cop,59 ; TX CTCSS On Input only Disable
; 960 = cop,60 ; Send MDC-1200 Burst (cop,60,type,UnitID[,DestID,SubCode])
; Type is 'I' for PttID, 'E' for Emergency, and 'C' for Call
; (SelCall or Alert), or 'SX' for STS (ststus), where X is 0-F.
; DestID and subcode are only specified for the 'C' type message.
; UnitID is the local systems UnitID. DestID is the MDC1200 ID of
; the radio being called, and the subcodes are as follows:
; Subcode '8205' is Voice Selective Call for Spectra ('Call')
; Subcode '8015' is Voice Selective Call for Maxtrac ('SC') or
; Astro-Saber('Call')
; Subcode '810D' is Call Alert (like Maxtrac 'CA')
; 961 = cop,61 ; Send Message to USB to control GPIO pins (cop,61,GPIO1=0[,GPIO4=1].....)
; 962 = cop,62 ; Send Message to USB to control GPIO pins, quietly (cop,62,GPIO1=0[,GPIO4=1].....)
; 963 = cop,63 ; Send pre-configured APRStt notification (cop,63,CALL[,OVERLAYCHR])
; 964 = cop,64 ; Send pre-configured APRStt notification, quietly (cop,64,CALL[,OVERLAYCHR])
; 965 = cop,65 ; Send POCSAG page (equipped channel types only)
; [functions-remote]
[telemetry]
;;;;; Telemetry ;;;;;
; Telemetry entries can be shared across all repeaters, or defined for each repeater.
; Can be a tone sequence, morse string, or a file
; |t - Tone escape sequence
; Tone sequences consist of 1 or more 4-tuple entries (freq1, freq2, duration, amplitude)
; Single frequencies are created by setting freq1 or freq2 to zero.
; |m - Morse escape sequence
; Sends Morse code at the telemetry amplitude and telemetry frequency as defined in the
; [morse] section.
; Follow with an alphanumeric string
; |i - Morse ID escape sequence
; Sends Morse code at the ID amplitude and ID frequency as defined in the
; [morse] section.
ct1=|t(1750,0,75,2048)(0,0,75,2048)(1750,0,75,2048)(0,0,1500,2048)(440,330,75,2048)
ct2=|t(660,880,150,2048)
ct3=|t(880,0,150,4096)
ct4=|t(1750,0,75,2000)(0,0,1500,0)(660,0,60,3000)(0,0,50,0)(660,0,160,3000)(0,0,50,0)(660,0,60,3000)
ct5=|t(660,0,150,2048)
ct6=|t(880,0,150,2048)
ct7=|t(660,440,150,2048)
ct8=|t(1750,0,75,2048)(0,0,1500,0)(660,0,60,3048)(0,0,40,0)(660,0,160,3048)(0,0,40,0)(660,0,60,3048)
remotetx=|t(1750,0,75,3000)(0,0,1500,0)(660,0,160,3000)(0,0,40,0)(660,0,60,3000)(0,0,40,0)(660,0,160,3000);
remotemon=|t(1209,0,50,2048)
cmdmode=|t(900,903,200,2048)
functcomplete=|mr
;|t(1000,0,50,2048)(0,0,50,0)(1000,0,50,2048)
patchup=rpt/callproceeding
patchdown=rpt/callterminated
; As far as what the numbers mean,
; (000,000,010,000)
; | | | |-------amplitude
; | | |-------------duration
; | |-------------------Tone 2
; |-------------------------Tone 1
; So, with 0,0,10,0 That says No Tone1, No Tone2, 10ms duration, 0 Amplitude.
; Use it for a delay. Fine tuning for how long before telemetry is sent, in conjunction with the telemdelay parameter)
; The numbers, like 350,440,10,2048 are 350Hz, 440Hz, 10ms delay, amplitude of 2048.
[morse]
;;;;; Morse code ;;;;;
; Morse code parameters, these are common to all repeaters.
speed = 20 ; Approximate speed in WPM
frequency = 800 ; Morse Telemetry Frequency
amplitude = 4096 ; Morse Telemetry Amplitude
idfrequency = 800 ; Morse ID Frequency
idamplitude = 1024 ; Morse ID Amplitude
;[morse]
;speed = 35 ; Not legal in the USA
;frequency = 800 ; Morse Telemetry Frequency
;amplitude = 4096 ; Morse Telemetry Amplitude
;idfrequency = 750 ; Morse ID Frequency *Changed
;idamplitude = 512 ; Morse ID Amplitude *Changed
[wait-times]
; A section for wait times can be defined for every repeater
telemwait = 1000 ; Time to wait before sending most telemetry
idwait = 500 ; Time to wait before starting ID
unkeywait = 1000 ; Time to wait after unkey before sending CT's and link telemetry
calltermwait = 2000 ; Time to wait before announcing "call terminated"
[wait-times_hd]
; Sample for half-duplex
telemwait = 100 ; Time to wait before sending most telemetry
idwait = 100 ; Time to wait before starting ID
[memory]
;;;;; Remote base memories ;;;;;
; Memories for remote bases (not for repeaters or hotspots). Seldom used.
;00 = 146.580,100.0,m
;01 = 147.030,103.5,m+t
;02 = 147.240,103.5,m+t
;03 = 147.765,79.7,m-t
;04 = 146.460,100.0,m
;05 = 146.550,100.0,m
[macro648490]
;;;;; Macro commands ;;;;;
1 = *711 *712 ; ident then time
2 = *711 ; ident only
3 = *81343679 ; hub connect
4 = *81143679 ; hub disconnect
5 = *806*903 ; disable
6 = *902*81343679 ; enable
7 = *81343679 ; hub connect backup
;[daq-list]
;;;;; Data Acquisition configuration ;;;;;
;Where: device_name1 and device_name2 are stanzas you define in this file
;device = daq-cham-1
;device = device_name1
;device = device_name2
;[daq-cham-1] ; Defined in [daq-list]
; Device name
;hwtype = uchameleon ; DAQ hardware type
;devnode = /dev/ttyUSB0 ; DAQ device node (if required)
;1 = inadc ; Pin definition for an ADC channel
;2 = inadc
;3 = inadc
;4 = inadc
;5 = inadc
;6 = inadc
;7 = inadc
;8 = inadc
;9 = inp ; Pin definition for an input with a weak pullup resistor
;10 = inp
;11 = inp
;12 = inp
;13 = in ; Pin definition for an input without a weak pullup resistor
;14 = out ; Pin definition for an output
;15 = out
;16 = out
;17 = out
;18 = out
;[meter-faces]
;face = scale(scalepre,scalediv,scalepost),word/?,...
; scalepre = offset to add before dividing with scalediv
; scalediv = full scale/number of whole units (e.g. 256/20 or 12.8 for 20 volts).
; scalepost = offset to add after dividing with scalediv
;face = range(X-Y:word,X2-Y2:word,...),word/?,...
;face = bit(low-word,high-word),word/?,...
; word/? is either a word in /usr/share/asterisk/sounds or one of its subdirectories,
; or a question mark which is a placeholder for the measured value.
; Battery voltage 0-20 volts
;batvolts = scale(0,12.8,0),rpt/thevoltageis,?,ha/volts
; 4 quadrant wind direction
;winddir = range(0-33:north,34-96:west,97-160:south,161-224:east,225-255:north),rpt/thewindis,?
; LM34 temperature sensor with 130 deg. F full scale
;lm34f = scale(0,1.969,0),rpt/thetemperatureis,?,degrees,fahrenheit
; Status poll (non alarmed)
;light = bit(ha/off,ha/on),ha/light,?
;[alarms]
;tag = device,pin,node,ignorefirst,func-low,func-hi
;tag = a unique name for the alarm
;device = daq device to poll
;pin = the device pin to be monitored
;ignorefirstalarm = set to 1 to throwaway first alarm event, or 0 to report it
;node = the node number to execute the function on
;func-low = the DTMF function to execute on a high to low transition
;func-high = the DTMF function to execute on a low to high transition
; a '-' as a function name is shorthand for no-operation
;door = daq-cham-1,9,1,2017,*7,-
;pwrfail = daq-cham-1,10,0,2017,*911111,-
[events]
;;;;; Events Management ;;;;;
;status,2 = c|f|RPT_NUMLINKS ; Say time of day when all links disconnect.
[controlstates]
;;;;; Control states ;;;;;
; Allow several control operator functions to be changed at once using one command (good for scheduling)
;statenum = copcmd,[copcmd]... https://wiki.allstarlink.org/wiki/Rpt.conf#Control_States_Stanza
0 = rptena,lnkena,apena,totena,ufena,noicd ; Normal operation
1 = rptena,lnkena,apdis,totdis,ufena,noice ; Net and news operation
2 = rptena,lnkdis,apdis,totena,ufdis,noice ; Repeater only operation
[schedule]
;;;;; Scheduler - execute a macro at a given time ;;;;;
;dtmf_function = m h dom mon dow ; ala cron, star is implied
;2 = 00 00 * * * ; at midnight, execute macro 2.
1 = 0 * * * * ; hourly voice ID
2 = 15 * * * * ; qrtr past
2 = 30 * * * * ; hlaf past
2 = 45 * * * * ; qrtr to
;4 = 00 22 * * * ; disable at 10pm
;7 = 00 07 * * * ; enable at 7am
#tryinclude "custom/rpt.conf"
#tryinclude "custom/rpt/*.conf"
;;;;;;;;;;;;;;;; Configure your nodes here ;;;;;;;;;;;;;;;;
; Note: there is no need to duplicate entire settings. Only
; place settings that are different than the template.
;;;;;;;;;;;;;;;;;;; Your node settings here ;;;;;;;;;;;;;;;;;;;
[648490](node-main)
macro=macro648490
duplex = 4
;;;;;;;;;;;;;;;;;;; Another node settings here ;;;;;;;;;;;;;;;;;;;
;[1998](node-main)
;startup_macro = *81345488
;morse = morse_1998 ; Sample morse stanza for node 1998
