If you are using Xipar then under the CLI use:
radio probe on
It will scan all currently connected Fobs and indicate bus and device number.
radio probe off
will stop the scan.
Edit the urd.conf file to set device parameters accordingly.
Restart Asterisk
On May 21, 2016 17:08, app_rpt-users-request@ohnosec.org wrote:
Send App_rpt-users mailing list submissions to
app_rpt-users@ohnosec.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of App_rpt-users digest…”
Today’s Topics:
usbradio_tune_xxxxx.conf where .conf = .confusion (Steve Agee)
Voter RTCM sometimes offline-mode but not when there is a
telnet connection (info@rainerbertsch.de)
Re: usbradio_tune_xxxxx.conf where .conf = .confusion (kk6ecm)
Re: usbradio_tune_xxxxx.conf where .conf = .confusion (Steve Agee)
Message: 1
Date: Sat, 21 May 2016 14:04:56 -0500
Subject: [App_rpt-users] usbradio_tune_xxxxx.conf where .conf =
.confusion
Message-ID: c5dc4bf0-2c2c-3566-f32e-31a311653463@earthlink.net
Content-Type: text/plain; charset=“windows-1252”; Format=“flowed”
Hello list:
I’ve searched
<http://www.xelatec.com/xipar/node/180>
and I fully understand the description/explanations given. What I don’t
understand, with specific attention to the lines:
; name=usb ;
; devnum=1 ;
devstr=4-2 ;
is how to manually uncomment, and manipulate them. In this particular
instance, I’m trying to get a DIAL box running with one original URI
(early version) using the USBRADIO channel driver, and one URIX (newer
version) using the SIMPLEUSB channel driver. I’ve followed the
step-by-step (or was that Crossbar 5 Duude?) instructions for starting
off with a single node, then adding the second node. That simply doesn’t
work. The second URIx green L.E.D. stays solid throughout the process.
Are these lines provided for informational purposes only, or can they be
edited to force the second device to be recognized and assigned?
N5ZUA
-------------- next part --------------
An HTML attachment was scrubbed…
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/7a2b5993/attachment-0001.html>
Message: 2
Date: Sat, 21 May 2016 22:02:45 +0200
From: “info@rainerbertsch.de” info@rainerbertsch.de
Subject: [App_rpt-users] Voter RTCM sometimes offline-mode but not
when there is a telnet connection
Message-ID: C881739D-1333-4A44-AF95-0167725A6BCE@rainerbertsch.de
Content-Type: text/plain; charset=“utf-8”
Hi there,
Since November, we are trying to build a voting system.
We need some help please !
Hardware:
Supermicro Intel Atom D525 (we also tried a RaspberryPi and an other computer)
Software: Since yesterday DIAL from Alllstar-Homepage (Before we tried it with ACID)
RTCM from Micro Node, Mark, we have 4 of them and tried all of them
Garmin GPS 18x LVC, also wie tried 4 of them.
Error:
More or less often the RTCM switch in the offline mode. When there is traffic very often.
But not if at the same time there is a telnet connection from any computer to the RTCM.
We suspect a networking problem between our asterisk-server and RTCM
Network-Card is set to 10 MB / s half-duplex like in the RTCM.
From tcpdump from server to rtcm we got:
??? snip ----------
GPSTime (cli0_yy): 05/05/16 12:48:01.000000000
SysTime: 05/05/16 12:48:01.040000
DrainTime: 05/05/16 12:48:01.000
Got GPS (cli0_yy): Lat: 4857.60N, Lon: 00915.01E, Elev: 214.4
sending KEEPALIVE (GPS) packet to client cli2_bprx digest bbb4c643
GPSTime (cli2_bprx): 05/05/16 12:48:01.000000000
SysTime: 05/05/16 12:48:01.300000
DrainTime: 05/05/16 12:48:01.240
Got GPS (cli2_bprx): Lat: 4853.16N, Lon: 00912.65E, Elev: 317.2
sending KEEPALIVE (GPS) packet to client cli0_yy digest 79d9c77d
GPSTime (cli0_yy): 05/05/16 12:48:02.000000000
SysTime: 05/05/16 12:48:02.040000
DrainTime: 05/05/16 12:48:02.000
[May 512:48:03]NOTICE[6559]:chan_voter.c:3632voter_reader:Voter
lost master timing source!!
sending packet challenge 200371797 digest 7749985d password BLAH sending packet challenge 200371797 digest 7749985d password BLAH sending packet challenge 200371797 digest bbb4c643 password BLAH GPSTime (cli2_bprx): 05/05/16 12:48:18.000000000
SysTime: 05/05/16 12:48:18.320000
DrainTime: 01/01/70 01:00:00.340
– Voter client cli0_yy disconnect (timeout)
??? snip ----------
Konfiguration of the Ethernet-Card
ethtool eth0
Settings for eth0:
Supported ports: [TP]
Supported link modes: 10baseT / Half 10baseT / Full
100baseT / Half 100baseT / Full
1000baseT / Full
Supported break frame use: No
Supports auto-negotiation: Yes
Advertised link modes: Not reported
Advertised break frame use: No
Advertised auto-negotiation: No
Speed: 10Mb / s
Duplex: Half
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: off
MDI-X: off (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv sample link
Does anyone have an idea what it may be ?
Why there is no problem with telnet at the same time and how can we run the system without this workaround
Rainer Bertsch
DF3SY
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/9ca14c8a/attachment-0001.html>
Message: 3
Date: Sat, 21 May 2016 13:55:40 -0700
Subject: Re: [App_rpt-users] usbradio_tune_xxxxx.conf where .conf =
.confusion
Message-ID: 638EEEDD093A4435AC75ECFA4CFB35E8@ThePykesHP
Content-Type: text/plain; charset=“us-ascii”
run lsusb at the command line, then set devstr=- for the
device(s) shown. Your example is for Bus 004 Device 002.
Bob
kk6ecm
[mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Steve Agee
Sent: Saturday, May 21, 2016 12:05 PM
Subject: [App_rpt-users] usbradio_tune_xxxxx.conf where .conf = .confusion
Hello list:
I’ve searched
; name=usb ;
; devnum=1 ;
devstr=4-2 ;
instance, I’m trying to get a DIAL box running with one original URI (early
version) using the USBRADIO channel driver, and one URIX (newer version)
using the SIMPLEUSB channel driver. I’ve followed the step-by-step (or was
that Crossbar 5 Duude?) instructions for starting off with a single node,
then adding the second node. That simply doesn’t work. The second URIx green
L.E.D. stays solid throughout the process. Are these lines provided for
informational purposes only, or can they be edited to force the second
N5ZUA
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/8eb8b1d0/attachment-0001.html>
Message: 4
Date: Sat, 21 May 2016 16:05:25 -0500
.confusion
Message-ID: 86a1038a-7c34-a1c4-edf1-89da5dead8a7@earthlink.net
Yup, tried that early on with no luck. Then tried using the (W) command
in both radio-tune-menu or simpleusb-tune-menu. The - listed
in the tuning files does not match what the “lsusb” command reports.
Well, the matches, but NOT the . On a working ACID install
under same conditions, I have two (count them two) different tuning
files where “devnum=3” go figure, and it works!
N5ZUA
Bob
kk6ecm
[mailto:app_rpt-users-bounces@ohnosec.org] *On Behalf Of *Steve Agee
.confusion
Hello list:
I’ve searched
don’t understand, with specific attention to the lines:
; name=usb ;|
; devnum=1 ;|
devstr=4-2 ;|
doesn’t work. The second URIx green L.E.D. stays solid throughout the
process. Are these lines provided for informational purposes only, or
can they be edited to force the second device to be recognized and
assigned?|
N5ZUA|
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160521/69ecfba1/attachment.html>
End of App_rpt-users Digest, Vol 87, Issue 33
