Usbradio ctcss from dsp allways keyed
hello all,
added a new radio to my ASL3 node but the usbradio dsp ctcss decode is stuck in keyed whether there is a signal or not. carrier is also set to dsp and the squelch works fine. audio through it sounds good. but it is in effect stuck in carrier squelch with no PL decode. tried several different tones. but result is the same.
other radios on the same node work fine.
any ideas and help would be appreciated.
thanks,
paul
from radio tune menu:
Receiver/Transmitter Status Display:
COS | CTCSS | COS | PTT
Input | Input | Out | Out
Clear | Keyed | Clear | Clear
INFO: RX CTCSS ADJUST START.
target=2400 tolerance=100
tries=0, setting=1.000000, meas=0
tries=1, setting=8.000000, meas=0
tries=2, setting=8.000000, meas=0
tries=3, setting=8.000000, meas=0
DONE tries=12, setting=8.000000, meas=0.00
ERROR: RX CTCSS GAIN ADJUST FAILED.
INFO: RX RSSI=992
usbradio config:
;! Automatically generated configuration file
;! Filename: usbradio.conf (/etc/asterisk/usbradio.conf)
;! Generator: chan_usbradio
;! Creation Date: Sun Oct 18 18:07:02 2026
[general]
node-main
hdwtype = 0 ; Leave this set to 0 for USB sound fobs modified using
rxboost = yes ; no - 20db attenuator inserted
rxctcssrelax = 1 ; reduce talkoff from radios w/o CTCSS TX HPF
rxsqhyst = 3000 ; Setting Squelch Hysteresis
;txctcssdefault = 100.0 ; default TX CTCSS frequency, any frequency permitted
;rxctcssfreqs = 100.0,91.5 ; RX CTCSS frequencies list in floating point. must be in table
;txctcssfreqs = 100.0,91.5 ; TX CTCSS frequencies list. any frequency permitted. will follow RX CTCSS frequency
rxctcssoverride = no ; Set to yes to start out in carrier squelch mode
carrierfrom = dsp ; no,usb,usbinvert,dsp,vox
voxhangtime = 2000 ; If carrierfrom=vox, mS to wait detecting RX audio before setting rxcarrierdetect=0
ctcssfrom = dsp ; no,usb,usbinvert,dsp
rxdemod = flat ; input type from radio: no,speaker,flat
rxsquelchdelay = 30 ; delayline in ms carrier squelch tail eliminator
rxondelay = 0 ; Number of 20mSec intervals following the release of PTT.
txoffdelay = 0 ; Ignore the receiver for a specified number of 20 millisecond
txboost = no ; Add transmitter audio gain boost: no,yes
txprelim = yes ; Audio processing on left output channel: no,yes
txlimonly = yes ; Audio limiting with no pre-emphasis on output channel: no,yes
txtoctype = notone ; Transmit tone control type: no,phase,notone
txmixa = composite ; Left channel output: no,voice,tone,composite,auxvoice
txmixb = no ; Right channel output: no,voice,tone,composite, auxvoice
rxlpf = 0 ; Receiver Audio Low Pass Filter 0,1 2
rxhpf = 0 ; Receiver Audio High Pass Filter 0,1
txlpf = 0 ; Transmitter Audio Low Pass Filter 0,1
txhpf = 0 ; Transmitter Audio High Pass Filter 0,1,2
invertptt = no ; Invert PTT: no,yes
duplex = 1 ; Duplex 0,1
duplex3 = 0 ; duplex 3 gain setting (0 to disable) ???
clipledgpio = 0 ; Enable ADC Clip Detect feature to use a GPIO output (0 to disable).
legacyaudioscaling = no ; If yes, continue to do raw audio sample scaling and clipping, resulting in Tx audio levels increasing
;;;;;;;;;;;;;;;; Configure your nodes here ;;;;;;;;;;;;;;;;
; this one works
1234
txboost = yes
txmixa = voice
;;;;; ASL3 Tune settings ;;;;;
devstr = 1-1:1.0
rxctcssfreqs = 203.5
txctcssfreqs = 203.5
rxmixerset = 750
txmixaset = 920
txmixbset = 500
rxvoiceadj = 0.637655
rxctcssadj = 1.546622
txctcssadj = 200
rxsquelchadj = 786
fever = 1
; this one does not work
4321
rxboost = no
rxctcssfreqs = 183.5
txmixa = no
devstr = 1-2:1.0
rxmixerset = 375
txmixaset = 500
txmixbset = 500
rxvoiceadj = 0.649457
rxctcssadj = 0.500000
txctcssadj = 200
rxsquelchadj = 800
fever = 1
try adding txctcssfreq = 183.5 to 4321
sorry made no difference.
this is a receive only input so none of the tx params were configured.
paul
For the node number you’re trying to get this working for, let’s call it node 1234:
  1. Are you loading the usbradio channel driver in /etc/asterisk/rpt.conf like this:
    • rxchannel = Radio/1234
If it’s not loaded, none of the usbradio settings will work.
Also, make sure that chan_usbradio.so is loaded in /etc/asterisk/modules.conf like this:
  • load => chan_usbradio.so
there are three other usb connected radios working on the computer.
everything works on this new radio except the ctcss decode.
from rpt.conf
the radio not working is the ...81.
the rest of rpt.conf [node-main] is default.
these snips match the 1234, 4321 nodes in the usbradio.conf i originally posted.
could it be i have run out of CPU?
it is a Pi5B. running Asterisk 22.4.1+asl3-3.5.4-1.deb12
still looking for something that could be killing the ctcss decode on 1 out of 4 radio.
thanks,
paul
What radio did you add? Brand and model?
The new radio needs to feed FLAT (discriminator) audio to the usb sound fob for the usb channel driver to decode the ctcss. Are you sure that radio in question feeds FLAT (discriminator) audio to the usb sound fob device?
it is an Icom IC-22U mobile radio. and yes it is discriminator audio.
the dsp squelch works. and the receive audio sounds fine out the other ports.
Are you sure of your settings?
Take a new look
carrierfrom=dsp
ctcssfrom=dsp
I could be wrong, but I think you need them both.
Have not done that in a long time so memory ????
the issue is not that it dosn't decode ctcss. it is that it always shows ctcss is active even when there is no signal or even no radio connected. and that the detect ctcss level option in radio-tune always fails.
we moved the radio to a different computer, same issue.
tried a different RA33, same issue.
carrierfrom=dsp and ctcssfrom=dsp are in the node-main stanza.
other radios on the same pc work fine with these same settings.
the only difference is duplex=0 as this is a transceiver.
not sure what else to try.
paul
Well, truthfully, I don't know just how that would react under duplex=0, but I suspect that may be the issue. I have only run it in repeater operation many times over.
Perhaps try duplex=1 and remove telemetry and hangtime by settings if they are an issue.
I hope you tapped the disc output prior to the de-emphasis circuit on the radio's main board and that's what you are using for rx audio into usbradio channel driver.
***Have you tried a different radio to rule out the ic-22u?***
