usbradio. conf
Group,
Recent install of listed build.
Asterisk GIT Version adaec47 built by root @ odroidxu4 on a armv7l │ running Linux on 2018-03-07 14:53:41 UTC
The problem I have ran into is when setting TX voice to 3.0 kHz I get a skipping of the tone. it goes away above 3.3 khc and below 2.9 kHz. the RX appears to be normal across the nodes I have connected to and save as expected.
I am using the Repeater- builder original RIM and where I has in previous version Dial of ASL installed for Raspberry pi the PL tone worked.out of TXmixB.
Is something different ?
Ryan n3ssl
[general]
[usb_27671]
        ; 0 = no (default)
                          ; 1 = yes
hdwtype = 0 ; Leave this set to 0 for USB sound fobs modified using
rxboost = 1 ; 0 - 20db attenuator inserted
        ; 1 - 20db attenuator removed
        ; Set to 1 for additonal gain if using a low-level receiver output
rxctcssrelax = 1 ; reduce talkoff from radios w/o CTCSS TX HPF
rxsqhyst = 375 ; Setting Squelch Hysteresis
                          ; 3000 is the default amount.
                          ; An amount of 500 seems good.
                          ; Then set the squelch to the highest number revealed when doing a "radio
                          ; tune rxsquelch" - running the command multiple (like 20) times in a row.
                          ; <http://allstarnode.com/wiki/lib/exe/fetch.php?media=asterisk-notes-wj8g.pdf>
txctcssdefault = 85.4 ; default TX CTCSS frequency, any frequency permitted
rxctcssfreqs = 85.4 ; RX CTCSS frequencies list in floating point. must be in table
txctcssfreqs = 85.4 ; TX CTCSS frequencies list. any frequency permitted. will follow RX CTCSS frequency
rxctcssoverride = 0 ; Set to 1 to start out in carrier squelch mode
carrierfrom = dsp ; no,usb,usbinvert,dsp,vox
        ; usb - from the COR line on the USB sound fob (Active high)
        ; usbinvert - from the inverted COR line on the USB sound fob (Active low)
        ; dsp - from RX noise using DSP techniques
        ; vox - voice activated from RX audio
ctcssfrom = dsp ; no,usb,usbinvert,dsp
        ; no - no CTCSS decoding, system will be carrier squelch
        ; usb - from the CTCSS line on the USB sound fob (Active high)
        ; usbinvert - from the inverted CTCSS line on the USB sound fob (Active low)
        ; dsp - CTCSS decoding using RX audio in DSP.
        ; rxdemod option must be set to flat for this to work.
rxdemod = flat ; input type from radio: no,speaker,flat
        ; flat - Use RX audio from discriminator (before de-emphasis)
rxsquelchdelay = 30 ; delayline in ms carrier squelch tail eliminator
rxondelay = 0 ; Number of 20mSec intervals following the release of PTT.
                          ; Uncomment and/or adjust for simplex nodes to eliminate "Ping Ponging"
                          ; or "Relay Racing". A positive value here will instruct the usbradio
                          ; driver to ignore the COR line for a specified number of 20mSec
                          ; intervals following the release of PTT. Use this ONLY on simplex
                          ; nodes, and leave commented out for repeaters or other full duplex nodes.
txboost = 1 ; Add transmitter audio gain boost: 0,1
txprelim = no ; Audio processing on left output channel: no,yes
        ; no - Audio is not pre-emphasized and limited.
        ; Suitable for use on a microphone input
        ; yes - Audio is pre-emphasized and limited.
        ; Suitable for direct connection to an FM modulator
txlimonly = no ; Audio limiting with no pre-emphasis on output channel: no,yes
        ; no - Audio is not limited.
        ; yes - Audio is limited.
        ; Suitable for transmitters with no limiting but with pre-emphasis.
txtoctype = notone ; Transmit tone control type: no,phase,notone
        ; phase - encode CTCSS and reverse phase
        ; AKA ("reverse burst") before unkeying TX
        ; notone - encode CTCSS and stop sending tone before unkeying TX
        ; AKA ("chicken burst")
txmixa = voice ; Left channel output: no,voice,tone,composite,auxvoice
        ; no - Do not output anything
        ; voice - output voice only
        ; tone - CTCSS tone only
        ; composite - voice and tone
        ; auxvoice - auxiliary voice output at headphone level for monitoring
txmixb = tone ; Right channel output: no,voice,tone,composite, auxvoice
invertptt = 0 ; Invert PTT: 0,1
        ; 0 - ground to transmit
        ; 1 - open to transmit
duplex = 1 ; Duplex 0,1
        ; 0 - half duplex
        ; 1 - full duplex
duplex3 = 0 ; duplex 3 gain setting (0 to disable) ???
rxlpf = 1 ; Receiver Audio Low Pass Filter 0,1 2
      ; 0 - 3.0 kHz cutoff (Default) value for reduced noise and increased intelligibility.
      ; 1 - 3.3 kHz cutoff for increased high end, sibilance and brightness.
      ; 2 - 3.5 kHz cutoff for even more high end, sibilance and brightness.
rxhpf = 1 ; Receiver Audio High Pass Filter 0,1
      ; 0 - 300 Hz cutoff. (Default) value to reduce sub-audible signals for retransmission and in the receiver speaker.
      ; 1 - 250 Hz cutoff for additional received and retransmitted bass response.
      ; recommend using this filter with a CTCSS tone no higher than 186.2 Hz.
txlpf = 1 ; Transmitter Audio Low Pass Filter 0,1
      ; 0 - 3.0 kHz cutoff. (Default) value.
txhpf = 1 ; Transmitter Audio High Pass Filter 0,1,2
      ; 0 - 300 Hz cutoff. (Default) value to reduce interference between voice and sub-audible signaling tones and codes.
      ; 1 - 250 Hz cutoff for increased bass response in transmitted audio.
      ; 2 - 120 Hz cutoff for special applications requiring additional bass response in transmitted audio.
      ; Not recommended due to the increased possibility of voice energy interfering with sub-audible signaling
Group, Recent install of listed build. Asterisk GIT Version adaec47 built
expected.
You're saying you don't have the adjustment range from the software tuning
values? I've seen this before, and the solution was always to pad it
externally and get the adjustment in a more linear region of the set point.
It's why I prefer the RA-40 adapters, no need to set the deviation in software.
TXmixB.
Well perhaps Kevin can chime in, but I don't think there was much different in
his RIM.
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
