I thought I’d pass along a working usbradio.conf for anyone trying to get an IRLP board going on Asterisk. Consider this file to be a template to get started with. I haven’t managed to get the AUX 1,2,3 outputs going yet, but PTT and COS seem to be working FB.
My node radios have built-in PL squelch, which I’m using at the moment. I’m also using the software DTMF decoder.
At this point, I’m using an unmodified CM108 fob and my homebrew IRLP
board.
Kyle
K0KN
; Usbradio channel driver Configuration File
[general]
[usb2210]
; IRLP board support
pp3 = ptt ; out0, out1 or ptt
; pp10 = in ; in, cor or ctcss
; pp12 =
in ; pins 10,12,13,15 are for DTMF
; pp13 = in
; pp15 = in
pp11 = cor
; pp4 = out0 ; pins 4,5,6 are AUX 1,2,3, default off
; pp5 = out0
; pp6 = out0
On Sun, Oct 31, 2010 at 11:10 PM, K&R Yoksh [email protected] wrote:
Hi all,
board.
Kyle
K0KN
[general]
[usb2210]
; pp12 =
; pp13 = in
; pp15 = in
pp11 = cor
; pp5 = out0
; pp6 = out0
We are no longer allowed to have IRLP on AllStarLink systems. Jim
removed all support for IRLP at Dave Cameron's request.
8-Dale
On Sunday, October 31, 2010 09:10:01 pm K&R Yoksh wrote:
Hi all,
I thought I'd pass along a working usbradio.conf for anyone trying to get
get started with. I haven't managed to get the AUX 1,2,3 outputs going
Open your mind, Read, Learn, Think, Apply.
AllStar Node 2392 / EchoLink node 541558 / 73, from N7PKT! http://www.hybotics.com - NEW main site
Just because we can, does it follow that we should?
yes, Dale, I believe they understand this. They are proposing the use of existing
IRLP hardware on an Asterisk node, having nothing to do with the IRLP network.
JIM
To: [email protected]
Date: Sun, 31 Oct 2010 21:31:39 -0700
Subject: Re: [App_rpt-users] usbradio.conf sample file for IRLP boards
Hi all,
removed all support for IRLP at Dave Cameron’s request.
8-Dale
Are you attempting to use usbradio with an IRLP board? That’s not going to work. You’ll need one of the usb attached C-Media sound dongles such as the URI or RA-35.
Does that help?
BTW, you dug up an 11 year old thread. Whatever you may have read there is probably obsolete.
