Yup, while it was cool before, but now that USB I/O is just not required. The little single board PCs are a far better proposition than a retired white-box, in almost every way, unless you don't want to pay $50 for a repeater controller.
The quad-core RPI3 and it's kin are the new easy, with so so so much I/O on board, and it's crazy-easy to use it.
What else can we put in software on these boards? MPPT controller?
Steve
On 18/03/16 15:56, Thor Wiegman <n7jct@aplaceonthe.net> @ohnosec.org wrote:
[....] why limit ourselves to using the audio chip for digital I/O?
For Pi and all others why not a USB relay board? [....]
some USB I/O boards for about $5 that give 16 pins, your
choice of input or output on each. If these could be adapted then
chan_simpleusb could be used and the radio can provide COR and CTCSS.
On my RasPI 2b I run (in addition to allstar) an APRS iGate using pyaprsmultimon and little cheap rtl-sdr, I have also turned several of the GPIO pins into relay controllers for remote power cycle of devices control etc.. I'm keeping the project documented at http://enhanced.girhub.io
Sent from the iRoad
