USB Radio
Date: 2009/10/26 Mon AM 10:40:38 PDT
To: "app_rpt-users@qrvc.com" <app_rpt-users@qrvc.com>
Subject: [App_rpt-users] USB Radio
Hi,
we are using an URI to connect a radio to an asterisk. To my mind the configuration of rpt.conf, usbradio.conf, iax.conf and extensions.ael is correct. We have the following problem:
1.) Outgoing radio from iaxrpt is working correct, PTT is triggered and voice is transmitted
2.) Incoming radio does not work. We get messages like "usbradio_read: rxcarrierdetect = 1" on the console but in iax (iax set debug on) we do _not_ get messages like RDKEY or RDUNKEY. Although no voice is transmitted to iax.rpt
What's going wrong? Thanks in advance,
Frank
DOHMEN, HERZOG & Partner GmbH
Soerser Weg 9
52070 Aachen
Gesch?ftsf?hrende Gesellschafter
Dr.-Ing. Marc Dohmen
Dr.-Ing. Frank Herzog
Amtsgericht Aachen HRB 5931
St.-Nr.: 201/5953/3633
USt-IdNr.: DE164205623
Diese Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e- mail is strictly forbidden.
App_rpt-users@qrvc.com
The default of CTCSS decode enabled in usbradio.conf is the likely cause. From mantis.qrvc.com bug ID 0000040:
You'd think the follwing entry would turn off ctcss:
ctcssfrom=no
It doesn't!
You also need to comment out rxctcssfreqs and txctcssfreqs to go into carrier squelch mode.
Steve
WA6ZFT
You are right, to comment out rxctcssfreqs and txctcssfreqs seems to solve the problem!
Thank you very much,
Frank
-----Ursprüngliche Nachricht-----
Von: hwstar@rodgers.sdcoxmail.com [mailto:hwstar@rodgers.sdcoxmail.com]
Gesendet: Montag, 26. Oktober 2009 20:44
An: Frank Herzog; app_rpt-users@qrvc.com
Betreff: Re: [App_rpt-users] USB Radio
Hi,
Frank
Soerser Weg 9
52070 Aachen
ctcssfrom=no
It doesn't!
Steve
WA6ZFT
Soerser Weg 9
52070 Aachen
Geschäftsführende Gesellschafter
