I have a few USB fobs resembling the one shown in the document titled “USB FOB to DB25 Interface”
Unfortunately the chip itself is potted die-on-board so access to signalling lines is limited to the additional components on board, which should seem simple enough to get to Pin 13 that feeds the Red LED to extract a PTT signal.
(I am able to assert COS- to Volume down and get received audio “to the net” experienced with WebTransceiver.)
Unfortunately metering ‘every’ available connection and toggling WebTransceiver’s Key/Transmit, none of the signal lines on the board react. I could imagine one line or the other might be open-collector and I’d have to add a pull-up to see a transition, but with the LED still in-circuit I’d think that would react. (The Green LED works as heartbeat just fine.)
Before I head to the local Frys and buy 1-2 each every fob they have to gut to see if I could get to the chip pins directly (or try to be patient and wait for Amazon)…
… I’m sitting here looking at a fully functional micro with a LOT of GPIO pins available… wondering why, aside from the IRLP s/w and interface options available… doesn’t an AllStar implementation leverage the on-board signalling?
I see there is Python code around to work with the GPIO, but not quite yet sure how or if I could create and call PTT and COR (and CTCSS) sense scripts within the AllStar configuration - ???
I know it would split out the radio audio v PTT/COS wiring harness just a bit vs the cute USB thing, but what the heck - buffer/interface parts on a small perf board tied to the GPIO pins and done? No?
Am I missing something? Code- and instructions-to-be?
You are missing something.... On most FOB's, regardless of the manufacturer, the RED LED is not wired to pin 13. While the green LED usually works correctly because it's tied to pin 12 on the C-Media chip, the red LED by default is connected to pin 21.
There are several reliable sources for non potted FOB's, but generally they cost more. The SYBA UAUD71 and the StarTech ICUSBAUDIO are two such units. They generally cost between $11 and $17 depending on supplier.
I've recently dropped the price of the RA-35 to include the CM119A and EEPROM to be presoldered.
Kevin
On 11/24/2016 3:20 PM, no1pc@yahoo.com wrote:
I have a few USB fobs resembling the one shown in the document titled "USB FOB to DB25 Interface"
(I am able to assert COS- to Volume down and get received audio "to the net" experienced with WebTransceiver.)
Unfortunately metering 'every' available connection and toggling WebTransceiver's Key/Transmit, none of the signal lines on the board react. I could imagine one line or the other might be open-collector and I'd have to add a pull-up to see a transition, but with the LED still in-circuit I'd think that would react. (The Green LED works as heartbeat just fine.)
Before I head to the local Frys and buy 1-2 each every fob they have to gut to see if I could get to the chip pins directly (or try to be patient and wait for Amazon)...
... I'm sitting here looking at a fully functional micro with a LOT of GPIO pins available... wondering why, aside from the IRLP s/w and interface options available... doesn't an AllStar implementation leverage the on-board signalling?
Thanks Kevin! Your work is legendary and has always been uniquely valuable to the community!
The ‘DSP’ schematics implied Pin 13 went to ‘a’ red LED without enough clarity for my brain to get this was an add-on/mod. (read the whole manual Jim!)
Your board is the next stop on the trail!!
This is for my a shielded/re-packaged BF-888 porta-node to go in the RV and the next will be tied to an RLC controller for our ‘landmark’ SF repeater site.
FOB’s, regardless of the manufacturer, the RED LED is not wired to
pin 13. While the green LED usually works correctly because it’s
Kevin
DB25 Interface”
Unfortunately the
Unfortunately
For something requiring small packaging, consider the RIM Lite models from Scott Zimmerman:
Kevin
The 'DSP' schematics implied Pin 13 went to 'a' red LED without enough clarity for my brain to get this was an add-on/mod. (read the whole manual Jim!)
This is for my a shielded/re-packaged BF-888 porta-node to go in the RV and the next will be tied to an RLC controller for our 'landmark' SF repeater site.
*To:* no1pc@yahoo.com; "App_rpt-users@ohnosec.org" <App_rpt-users@ohnosec.org>
*Sent:* Thursday, November 24, 2016 2:11 PM
*Subject:* Re: [App_rpt-users] USB FOB not affecting Pin 13 to PTT
To unsubscribe from this list please visithttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
For this weekend only, I am running a Black Friday / Cyber Monday discount of 10% on all Repeater-Builder products. Items MUST be ordered before midnight Tuesday to receive the discount.
Scott
Scott Zimmerman
Amateur Radio Call N3XCC
474 Barnett Road
Boswell, PA 15531
On 11/24/2016 8:36 PM, Kevin Custer wrote:
Jim,
to pin 21.
