I have set up an additional ASL node (548274) on 220MHz using a URI connected to a BCR repeater. Having performed node setup many times, this one has me stumped. The node is registered and receiving node updates. But the green connection on the URI is a solid green when it should be blinking. I have checked all port (4567) instances in the required files. The software is ASL beta 6.
Asterisk is not happy. If s restart does not correct it, there is likely a typo in one of the config files.
Bob
K6ECM
Bob, you were correct. I must have hosed up somewhere in the *.conf files. So instead of searching for my error, I created a new instance of ASL beta 6 and now all is well in ASL-land.
James, KM7KK
