Here is the diag file from the node. In modules.conf, chan_simpleusb.so is uncommented
Call sign: KM7KK
Interface type: SimpleUSB/usb_458272 ; SimpleUSB
Echolink Callsign: INVALID
Echolink node: 000000 ASL node used:
Ping test to 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=116 time=1746 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=116 time=697 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=116 time=610 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=116 time=612 ms
— 8.8.8.8 ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 52ms
rtt min/avg/max/mdev = 610.336/916.498/1745.973/480.190 ms, pipe 2
Ping test to register.allstarlink.org
PING register.allstarlink.org (162.248.92.131) 56(84) bytes of data.
64 bytes from v-162-248-92-131.unman-vds.premium-chicago.nfoservers.com (162.248.92.131): icmp_seq=1 ttl=49 time=740 ms
64 bytes from v-162-248-92-131.unman-vds.premium-chicago.nfoservers.com (162.248.92.131): icmp_seq=2 ttl=49 time=580 ms
64 bytes from v-162-248-92-131.unman-vds.premium-chicago.nfoservers.com (162.248.92.131): icmp_seq=3 ttl=49 time=613 ms
64 bytes from v-162-248-92-131.unman-vds.premium-chicago.nfoservers.com (162.248.92.131): icmp_seq=4 ttl=49 time=634 ms
— register.allstarlink.org ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 607ms
rtt min/avg/max/mdev = 579.757/641.410/739.604/59.848 ms
Ouput of ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.42.77 netmask 255.255.255.0 broadcast 192.168.42.255
ether d8:3a:dd:56:d1:b6 txqueuelen 1000 (Ethernet)
RX packets 409 bytes 452020 (441.4 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 340 bytes 20399 (19.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether d8:3a:dd:56:d1:b8 txqueuelen 1000 (Ethernet)
Output of lsmod grep dahdi
dahdi_dummy 16384 0
dahdi_transcode 16384 0
dahdi 237568 2 dahdi_dummy,dahdi_transcode
crc_ccitt 16384 1 dahdi
IAX2 registry
No such command ‘iax2 show registry’ (type ‘help iax2 show’ for other possible commands)
Asterisk version:
Asterisk GIT a4245fb built by @ raspberrypi on a armv7l running Linux on 2021-03-24 18:08:36 UTC
Current date and time: 2023-10-16.21:52
updatenodelist service running?
root 750 0.0 0.0 4396 492 tty1 S+ 21:55 0:00 grep updatenodelist
/tmp/rpt_extnodes-temp file
-rwx------ 1 root root 2042 Oct 16 21:54 /tmp/rpt_extnodes-temp
/var/lib/asterisk/rpt_extnodes file
lrwxrwxrwx 1 root root 17 Mar 24 2021 /var/lib/asterisk/rpt_extnodes → /tmp/rpt_extnodes
####### Begin warnings from messages file
[Mar 24 18:29:39] WARNING[684] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[Mar 24 18:29:39] WARNING[684] chan_iax2.c: Unable to open IAX timing interface: No such file or directory
[Oct 16 20:16:11] WARNING[573] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[Oct 16 20:16:12] WARNING[573] chan_iax2.c: Unable to open IAX timing interface: No such file or directory
[Oct 16 20:16:16] WARNING[628] chan_simpleusb.c: Loaded parameters from simpleusb_tune_usb_458272.conf for device usb_458272 .
[Oct 16 20:16:49] WARNING[594] app_rpt.c: rpt_thread restarted on node 458272
[Oct 16 20:16:50] WARNING[640] chan_simpleusb.c: Loaded parameters from simpleusb_tune_usb_458272.conf for device usb_458272 .
[Oct 16 20:16:50] WARNING[640] chan_simpleusb.c: Unable to re-open DSP device 2 (usb_458272): Device or resource busy
[Oct 16 20:17:00] WARNING[640] chan_simpleusb.c: select failed: Interrupted system call
[Oct 16 20:17:03] WARNING[639] chan_simpleusb.c: Possibly stuck USB read channel. [usb_458272]
[Oct 16 20:17:03] WARNING[639] chan_simpleusb.c: Nope, USB read channel [usb_458272] wasn’t stuck after all.
[Oct 16 20:22:45] WARNING[558] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 20:22:45] WARNING[558] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 20:31:21] WARNING[574] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 20:31:21] WARNING[574] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 20:42:42] WARNING[569] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 20:42:42] WARNING[569] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 20:47:56] WARNING[565] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 20:47:56] WARNING[565] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 20:53:21] WARNING[560] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 20:53:21] WARNING[560] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 21:07:40] WARNING[565] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 21:07:40] WARNING[565] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 21:20:28] WARNING[570] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 21:20:28] WARNING[570] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 21:38:32] WARNING[568] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 21:38:32] WARNING[568] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 21:46:52] WARNING[569] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 21:46:52] WARNING[569] loader.c: No ‘modules.conf’ found, no modules will be loaded.
[Oct 16 21:52:39] WARNING[559] config.c: parse error: No category context for line 18 of /etc/asterisk/modules.conf
[Oct 16 21:52:39] WARNING[559] loader.c: No ‘modules.conf’ found, no modules will be loaded.
####### Begin warnings from messages.1 file
