Where and what script do I run to force an update to the database that populates node info in Supermon2? After a power outage my node running Supermon2 restarted but all the connected nodes show as “Node not in database”. Thx. Adrian VE7NZ
For Allmon and I assume Supermon, there should be an astdb.php file somewhere on your server. Different builders put it in different places. Do a which astdb.php at the Linux CLI. If that finds is you can then just type astdb.php.
Normally that runs once a day. Maybe if you wait a day it will update.
