Update issue (different node from previous post)
Cockpit update replies: Loading available updates failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.sury.org/php bookworm InRelease: The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key deb@sury.org E: https://packages.sury.org/php bookworm InRelease is not (yet) available (The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key deb@sury.org)
Please reload the page after resolving the issue.
k5tra
OS Kernel : 6.12.75+rpt-rpi-v8
Asterisk : 22.7.0+asl3-3.7.1-1.deb12
ASL [app_rpt] : 3.7.1
Installed ASL packages :
Package Version
allmon3 1.7.0-1.deb12
asl3 3.15-1.deb12
asl3-asterisk 2:22.7.0+asl3-3.7.1-1.deb12
asl3-asterisk-config 2:22.7.0+asl3-3.7.1-1.deb12
asl3-asterisk-modules 2:22.7.0+asl3-3.7.1-1.deb12
asl3-menu 1.16-1.deb12
asl3-pi-appliance 1.10.1-1.deb12
asl3-update-nodelist 2.0.0-1.deb12
asl-apt-repos 2.0-1.deb12
cockpit 287.1-0+deb12u3
cockpit-ws 287.1-0+deb12u3
dahdi 1:3.1.0-2
dahdi-dkms 1:3.4.0-10.asl.deb12
dahdi-linux 1:3.4.0-10.asl.deb12
dahdi-source 1:3.4.0-10.asl.deb12
This is not an ASL issue. Wherever you're running this from has a non-standard package library configured for PHP. So you configured Linux on that system to replace the stock PHP with the Sury.org repo. That's fine, but not supported or recommended because that usually means someone tried to get the bleeding edge PHP or a very old PHP.
You'd need to reconfigure the sury.org repository for that node with proper keys.
Yeah, this one is a bit different because it is also a DVSwitch & Analog Bridge.
Tom
