i am brand new to Allstar, this is my 1st attempt to get a node up and running.
here is my 1st issue:
“Applying updates failed”
E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
Please reload the page after resolving the issue.
This is just the start When i load Allmon3 there is not any node info
Also when i load supermon all i get is a page of txt
I ran the command , alot of text scrolled by no change on my Allmon3 page
i rebooted , ran the command again and nothing happened, just returned to the prompt
