Unwanted reorder or fast busy tone
Subject: Rhythmic ~2Hz "fast busy/reorder"-style tone injected into audio bridge only when linktolink duplex=0 link is established — persists across two different RIM devices, all gain/duplex settings, unrelated to downstream hardware
Setup:
  • ASL3, Raspberry Pi
  • Node 1998: Voter/1998 — receiver-voting node (BridgeCom BCR + MT500 RTCM clients), duplex = 2
  • Node 1996: SimpleUSB/usb_1996 — USB RIM interfacing into an Arcom RC210 port, duplex = 0 in rpt.conf, linktolink = yes (the documented special case for interfacing with an external multiport controller)
  • Linked via: rpt cmd 1998 ilink 3 1996 (transceive)
Symptom:
A rhythmic tone — described by ear as sounding like a telco fast-busy/reorder signal — begins the moment the 1998↔1996 link is established and continues indefinitely (only clears on a full systemctl restart asterisk). Specifics:
  • Absent when node 1996 is up standalone, before the link to 1998 is made — only appears once bridged
  • Rides on top of real, clean receive audio (tested with a calibrated RTCM, 1kHz tone at 3kHz deviation, CTCSS present) — both are audible simultaneously, unaffected by each other
  • Identical behavior across two different physical USB RIM devices (a generic CM108-based unit and a Masters Communications RA-33)
  • RPT_TXKEYED on both nodes shows a constant 1 throughout — never flaps — consistent with the documented "Special Case: Full duplex if linktolink is set to yes" behavior, so this isn't a PTT/key-state toggle
  • Unaffected by: txmixaset (tested 200–900), USB port, physical distance from RF sources, duplex in rpt.conf's [1996] stanza (tested 0 and 2), duplex in simpleusb.conf's [usb_1996] stanza (tested 0 and 1, inherited from [node-main]), propagate_dtmf (tested yes/commented out on both nodes), carrierfrom/ctcssfrom (tested no and usbinvert)
  • Zero corresponding entries in /var/log/asterisk/messages.log at NOTICE/WARNING level correlating with the tone's timing, even with continuous tail -f capture through multiple full cycling episodes
  • A separate, unrelated RC210-side issue (Port 1's "Repeater Mode" checkbox) was found and fixed during this troubleshooting — confirmed not the cause, since disabling it did not stop the tone
Config excerpts (rpt.conf, simpleusb.conf, modules.conf) available on request — happy to post directly or via pastebin.
Question: Given the tone only appears once bridged (never standalone), persists regardless of hardware/gain/duplex settings on both sides, and sounds like Asterisk's own Congestion()/reorder indication — is this a known interaction between chan_voter's mix-mode client protocol and the linktolink=yes/duplex=0 softmix bridge? Is there a way to get debug-level tracing on the actual bridge/dial leg between these two channels that would surface in the log?
Happy to provide a debug-level capture, full config files, or test anything else on request.
We added a fix for this in the latest build. Please ping us if 3.10.x does not address it (when it's released, or if you want to try beta, let us know sooner :slight_smile: )
This is not a working system at the moment so I would try the beta. Thanks.
Bob
K6MBY
Installed v 3.10.4-1. Confirmed with
$ apt-cache policy asl3-asterisk
asl3-asterisk:
Installed: 2:22.10.1+asl3-3.10.4-1.deb13
Candidate: 2:22.10.1+asl3-3.10.4-1.deb13
Version table:
Update: tested on the new beta release — cycling tone still present, unchanged.
Same reproduction steps as my original report: link established (rpt cmd 1998 ilink 3 1996), tone begins immediately, persists until a full Asterisk restart. No change in behavior, character, or timing that I could detect.
Bob
K6MBY
First, I am not this smart. I am using Claude.ai to help diagnose this issue.
Update: confirmed via spectral analysis — this IS Asterisk's Congestion()/fast-busy indication tone
I recorded the cycling audio using app_rpt's archivedir feature (recording on node 1998) and ran a spectral analysis on the capture. Results:
  • Rhythmic bursts every ~0.5 seconds, consistent throughout a 195-second recording (354 onset events)
  • Dominant frequencies: 480 Hz and 620 Hz — this is the exact standard North American telco "fast busy"/reorder tone pair, matching Asterisk's own Congestion() indication as defined in indications.conf
So this isn't a hardware artifact, USB noise, or coincidental buzz — Asterisk is genuinely generating and injecting its own Congestion tone into the audio stream repeatedly while the link is up.
Also worth noting:
  • The tone is not 100% reproducible on every single rpt cmd 1998 ilink 3 1996 attempt — most attempts trigger it, but occasionally a link comes up clean with no tone at all. This may point to a timing/race condition rather than a purely deterministic config interaction.
  • Confirmed present on: two different physical USB RIM devices, a beta ASL3 release, and a completely fresh SD card flash of the current stable release with configs restored from a known-good backup — rules out hardware, package-version, and install-state causes.
  • IAX2 debug logging during a confirmed cycling episode shows completely normal control-plane traffic (standard LAGRQ/LAGRP/PING/PONG cadence, zero retries/errors) — the tone isn't an IAX2 transport issue, it's being generated as actual audio content somewhere in the bridge/channel logic.
Given the tone is specifically Congestion()/reorder — normally played when a call setup or dial attempt fails — this suggests something in the linktolink=yes/duplex=0 bridge path between a Voter channel and a SimpleUSB channel is intermittently hitting a failure/retry condition internally and signaling it audibly, even though the link itself (per rpt lstats) shows as ESTABLISHED and stable the whole time.
Bob
K6MBY
Q? have you made ANY changes to your /etc/asterisk/extensions.conf file?
Note: an unmodified copy of the file can be found @ /usr/share/doc/asl3-asterisk-config/examples/configs/asl3/extensions.conf)
Confirmed — ran diff against the unmodified copy at /usr/share/doc/asl3-asterisk-config/examples/configs/asl3/extensions.conf and there are no differences at all. My /etc/asterisk/extensions.conf is stock, unmodified.
OK, doing some digging. Not sure "why" this changed at the moment. It's one of those head scratchers.
During an active tone episode:
core show channels verbose — look for a channel with an active generator
bridge show all — which member is feeding TX conf
Provide the following and it will make this easier to debug.
Worth noting on timing: this started specifically when I was testing propagate_dtmf = yes while sending real DTMF tones through an RTCM into the voter node — not just from adding the config line itself (I later tested with propagate_dtmf commented out again, and the cycling persisted regardless). So it may be tied to something about a DTMF sequence being decoded/processed at that time, even though it's not required to reproduce it afterward.
One detail that might matter: my rpt.conf function table has the autopatch codes (61/62 → autopatchup/autopatchdn) commented out/disabled — so I wouldn't expect a DTMF sequence to be able to trigger a real autopatch request through normal function-code handling. That makes the stuck Local/Autopatch@default channel in Ring state (from the core show channels verbose output) more puzzling — not sure what's actually opening it if autopatch isn't enabled.
sudo asterisk -rx "core show channels verbose"
sudo asterisk -rx "bridge show all"
Channel Context Extension Prio State Application Data CallerID Duration Accountcode PeerAccoun t BridgeID
Recorder/PChan-00000000;2 default s 1 Up (None) (Empty) 00:00:18 b7e2e667-c674-452c-b
Recorder/PChan-00000000;1 default s 1 Up (None) (Empty) 00:00:18
SimpleUSB/usb_1996 default 1 Up Rpt Repeater Rx 00:00:18
Recorder/MonChan-00000002;1 default s 1 Up (None) (Empty) 00:00:18
Recorder/MonChan-00000002;2 default s 1 Up (None) (Empty) 00:00:18 ae7f7b44-a45f-4376-a
Announcer/IAXLink-0000000e;1 default s 1 Up (None) (Empty) 00:00:11
Announcer/IAXLink-0000000e;2 default s 1 Up (None) (Empty) 00:00:11 003149f4-4d0e-4ca5-b
Local/LocalTX@default-00000005;2 default LocalTX 1 Up (None) (Empty) 00:00:18 7ad6d844-481a-426e-b
Local/LocalTX@default-00000005;1 default LocalTX 1 Up (None) (Empty) 00:00:18
Recorder/MonChan-00000006;1 default s 1 Up (None) (Empty) 00:00:18
Recorder/MonChan-00000006;2 default s 1 Up (None) (Empty) 00:00:18 7ad6d844-481a-426e-b
Announcer/Telemetry-0000000f;1 default s 1 Up (None) (Empty) 00:00:09
Announcer/Telemetry-0000000f;2 default s 1 Up (None) (Empty) 00:00:09 ae7f7b44-a45f-4376-a
Announcer/TXPChan-00000008;1 default s 1 Up (None) (Empty) 00:00:18
Announcer/TXPChan-00000009;1 default s 1 Up (None) (Empty) 00:00:18
Announcer/TXPChan-00000008;2 default s 1 Up (None) (Empty) 00:00:18 ae7f7b44-a45f-4376-a
Announcer/TXPChan-00000009;2 default s 1 Up (None) (Empty) 00:00:18 7ad6d844-481a-426e-b
Local/LocalTX@default-00000001;2 default LocalTX 1 Up (None) (Empty) 00:00:18 ae7f7b44-a45f-4376-a
Local/LocalTX@default-00000001;1 default LocalTX 1 Up (None) (Empty) 00:00:18
Announcer/RXPChan-00000007;1 default s 1 Up (None) (Empty) 00:00:18
Announcer/RXPChan-00000007;2 default s 1 Up (None) (Empty) 00:00:18 003149f4-4d0e-4ca5-b
Announcer/IAXLink-0000000c;2 default s 1 Up (None) (Empty) 00:00:11 b7e2e667-c674-452c-b
Announcer/IAXLink-0000000c;1 default s 1 Up (None) (Empty) 00:00:11
IAX2/127.0.0.1:4569-13724 radio-secure 1996 14 Up Rpt 1996 1998 00:00:11
Announcer/RXPChan-00000003;1 default s 1 Up (None) (Empty) 00:00:18
Announcer/RXPChan-00000003;2 default s 1 Up (None) (Empty) 00:00:18 b7e2e667-c674-452c-b
Local/Autopatch@default-0000000a;2 default Autopatch 1 Ring (None) (Empty) 00:00:16
Local/Autopatch@default-0000000a;1 default Autopatch 1 Down (None) (Empty) 00:00:16
IAX2/127.0.0.1:4569-78 1996 1 Up Rpt Remote Rx 00:00:11
Recorder/PChan-00000004;2 default s 1 Up (None) (Empty) 00:00:18 003149f4-4d0e-4ca5-b
Recorder/PChan-00000004;1 default s 1 Up (None) (Empty) 00:00:18
voter/1998 default 1 Up Rpt Repeater Rx 00:00:18
Local/GenChannel@default-0000000b;2 default GenChanne l 1 Up (None) (Empty) 00:00:16 b7e2e667-c674-452c-b
Local/GenChannel@default-0000000b;1 default GenChanne l 1 Up (None) (Empty) 00:00:16
34 active channels
1 active call
1 call processed
Bridge-ID Name Chans Type Technology Dur ation
003149f4-4d0e-4ca5-bd04-d4d5dfe1c07e CONF 3 base softmix 00: 00:19
7ad6d844-481a-426e-b99c-7dce910e172d TXCONF 3 base softmix 00: 00:19
ae7f7b44-a45f-4376-a96c-42b3a243232f TXCONF 4 base softmix 00: 00:19
b7e2e667-c674-452c-b08d-9d252bee23e1 CONF 4 base softmix 00: 00:19
Well, these guys (GenChannel) are only supposed to be created in the autopatch code:
Wonder how we are triggering that...
I'm thinking our problem is here:
If we are in "simple" autopatch mode, the local_dtmp_helper is launching the autopatch function...
This is set to "simple" if there is no functions configured.
Something to check/try?
Ran the test with both RTCMs completely disconnected — zero possible DTMF source anywhere in the system, voter node confirmed showing no connected clients. Local/Autopatch@default (Ring/Down) and Local/GenChannel@default still appear identically, ~13 seconds after establishing the link — same as before.
This rules out DTMF entirely. Whatever's opening that autopatch channel happens purely from establishing the link between the Voter node (1998) and the SimpleUSB node (1996) in duplex=0/linktolink=yes mode — no DTMF, no RTCM, no real signal of any kind required.
Can you share your config files with us? Make sure to hide any secrets in there.
FWIW, the DTMF code path is followed with startup scripts.
There are only 2 paths to run the code which creates the GenChannel (that I see).
Option 1 is simple patch mode (shown above)l
Option 2 is using a macro that call autopatchup function under [functions]
Option 1 is "enabled" when there is no [functions] making "option 2" not possilble.
It may help to have a [functions] context and maybe even leave 61 and 62 so that *is not the "only" way to bring up the autopatch.
Another way to "prove" it's in simple mode would be to send a #* on the channel to hangup - that "should" clear the fast busy.
rpt.conf.txt (35.0 KB)
voter.conf.txt (5.6 KB)
simpleusb.conf.txt (8.6 KB)
Sending # does stop the reorder tone.
I un-commented 61 and 62 in functions with no change.
Leaving. Back after 3:30 pm today
OK, I think the rpt.conf is "malformed". I believe the config for [1996] is not seeing the functions=functions config.
Move [1996] and [1998] to the end of the original [node-main](!) template. Keeping your specific config for each node.
Then add (node-main) ->
1996 and
1998
On Wed, Aug 26, 2026 at 2:12 PM Bob <[email protected]> wrote:
Someone replied to your post.
| K6MBY
August 26 |
Bad format - add
[1996](node-main)
[1998](node-main)
I would also suggest that you carefully read the ASL Manual : Asterisk Templates page.
Then, take a look at the template configuration files that were packaged with ASL3 and compare those with your modified .conf files :
  • /usr/share/doc/asl3-asterisk-config/examples/configs/asl3/rpt.conf
  • /usr/share/doc/asl3-asterisk-config/examples/configs/asl3/simpleusb.conf
If you look at (and understand) your rpt.conf file, your [1998] node is only setting "6" variables.
In your simpleusb.conf file, you set a few variables for [usb_1996] but inherits none of the template settings. I'm also curious about your hiddev = /dev/hidraw0 setting, one that does not exist in ASL3.
... and those are just a few examples of where your configuration files have strayed.
Moving the 1996 and 1998 to the end into the template area and adding the [node-main] appears to have fixed the issue. I now get a voice indicating the two nodes are linked.
[1996](node-main)
rxchannel = SimpleUSB/usb_1996
duplex = 0
startup_macro = *31996
startup_macro_delay = 20
linktolink = yes
archivedir = /var/spool/asterisk/monitor
archiveformat = wav
[1998](node-main)
rxchannel = Voter/1998
duplex = 2
archiveformat = wav
And Alan, yes, had I read and understood how Asterisk uses templates it would have likely saved the time and frustration
Thank you all for hanging in with me to solve this mistake.
Bob
k6mby
Excellent.
The templated configurations are "different" from other/older AllStarLink software packages but they do add / offer a lot of flexibility, especially for those with multiple nodes on the same server.
