Unauthenticated Connection?
Need some help. Running two nodes on a single server (Node 540840) and a repeater node (Node 540841) at another site that is trying to connect to one of the sever nodes. It has been working for a couple of days now but seeing the following error on the sever (540840). I suspect the IP changed on one side but not sure how to resolve this. Any ideas? I do have a line on the server side RPT.conf to delineate the two nodes (526030 = radio@127.0.0.1:4569/526030,NONE
540840 = radio@540840.ip.hamvoip.org:4569/540840,NONE)
Accepting UNAUTHENTICATED call from 172.58.19.197:
> requested format = ulaw,
> requested prefs = (ulaw|g726aal2|ilbc|gsm),
> actual format = ulaw,
> host prefs = (ulaw|adpcm|g722|g726aal2|gsm|ilbc),
> priority = mine
– Executing [540840@radio-secure:1] Rpt(“IAX2/172.58.19.197:48624-2903”, “540840”) in new stack
[May 10 08:36:37] WARNING[32094]: app_rpt.c:22930 rpt_exec: Node 540841 IP 172.58.19.89 does not match link IP 172.58.19.197!!
== Spawn extension (radio-secure, 540840, 1) exited non-zero on ‘IAX2/172.58.19.197:48624-2903’
– Hungup ‘IAX2/172.58.19.197:48624-2903’
While I could be wrong,
I think the conectee does not have a updated nodeslist that contains the node that can’t be authenticated for connection.
Look at the date/time of file…
/var/lib/asterisk/rpt_extnodes
should be <30min old
Look in the file to see if the node in question is in there.
One other thing I guess I should ask…
is the second server behind the same network NAT somehow ?
