Did you get this resolved yet? If not, maybe try this method…
1: Download and install to a 32 gig thumb drive the latest AllstarLink ASL 2.0.0.beta image — I use Etcher for this process,
2: Start up your Wyse 3040, hit Del several times during the beginning of the boot up so that it gets you to the bios setup screen,
3: Check your date & time – set it as needed, I have found if date off by far due to low on-board battery the system will hang, this has eaten my lunch more than once on occasion,
4: Select “Advance” tab, scroll down to “SATA MODE” and select “AHCI”, then scroll down more to “Boot Mode”, there you will have option for “Legacy/UEFI/Both” — even though mine said for “64 bit OS use Both” it didn’t work for me, finally I selected “Legacy” and off it went flying like a charm,
5: Then select “Boot Tab” — make sure that your thumb drive is in the number one spot (use the + or - move your selection up or down) and that your "SATA 0 (that’s a zero not a oh no) is in number two spot,
6: select Exit Tab, save and exit,
it should now boot and start the install process.
This worked for me on all the Wyse 3040’s, 5020’s, and 5060’s thin Clients here so hopefully it will work for you. No promises, no guarantees as they say.
The ASL Beta installs nice and clean — easy-peasy, and generally works well at first install either as a radioless node or radio node/repeater controller. As a repeater controller using the RIM-Maxtrac_RM interface between repeater/radio and Wyse machine it sets up and runs first go around — as long as you pay attention to what you are doing which I didn’t do a few times and it caused me pains in my you know what. If using the RIM-Maxtrac-RM I use the “simpleusb_tune” and not the usb_tune mode and all usually sets up and requires no further adjustments — of course that will depend on your radio(s) being used.
