Unable to get inbound connections
I am unable to receive inbound connections on both my nodes. I have port forwarded the router and set different ports on each raspberry pi node. One node is setup as a shari pi hat the other is a hub. I even tried to DMZ the node and still can not connect. Both nodes can connect outbound. They do not connect to each other on the same network. I have even tried to connect using repeater phone with no luck. I get the time out error in the CLI when attempting to connect. I don’t see a attempt to connect on the CLI of the inbound node.
I am using a Asus router in mesh mode. Both devices are connected to the main router.
Cox cable internet
Arris cable modem
Please run and provide the output of asl-node-auth-check
I was able to solve this issue. I had to tell the nodes about their neighbors in the rpt.conf file. Thanks for trying to help.
Mike
KS7URV
