So… I’ve been at this for days and I’m at my wits end. I’m computer literate but not so much with linux and command line.
I got debian12 installed on my mini pc and got ASL installed on that. I was able to configure it. I want to run stand alone on that device until I can get a usb interface.
I’m not even sure if my AllStar node is working. I wanted to log in with iaxRpt but that doesn’t work. Or with the RepeaterPhone app for ios.
I got to the step of installing allmon3 and was able to edit the allmon3.ini file once but now I can’t even seem to get there again. Why I try to cd to that directly it says that it doesn’t exist even though when I type “ls” to list the directories I can see it there. I’ve tried with sudo and it gives the same result.
How can I test to see if my node is even working?
How can I regain access to the allmon3.ini file?
Any help is greatly appreciated.
Gord
EDIT; I removed link to photo and figured out how to copy the code below
gf@debian:/etc$ ls -ld /etc/allmon3
drwxr-xr-x 2 root root 4096 Dec 15 09:39 /etc/allmon3
gf@debian:/etc$ ls -l /etc/allmon3
total 32
-rw-rw---- 1 allmon3 allmon3 2326 Dec 15 09:39 allmon3.ini
-rw-r–r-- 1 root root 2741 Oct 28 11:39 custom.css
-rw-r–r-- 1 root root 2092 Oct 28 11:39 menu.ini.example
-rw-r–r-- 1 root root 1050 Oct 28 11:39 nginx.conf
-rw-rw---- 1 allmon3 allmon3 314 Oct 28 11:39 user-restrictions
-rw-rw---- 1 allmon3 allmon3 96 Dec 15 09:41 users
-rw-r–r-- 1 root root 4420 Dec 15 09:32 web.ini
I also appear to be getting this over and over again every few seconds.
[2024-12-15 19:39:41.337] NOTICE[2349]: manager.c:3790 authenticate: 127.0.0.1 failed to authenticate as ‘admin’
== Connect attempt from ‘127.0.0.1’ unable to authenticate
[2024-12-15 19:39:57.354] NOTICE[2350]: manager.c:3790 authenticate: 127.0.0.1 failed to authenticate as ‘admin’
[2024-12-15 19:40:13.371] NOTICE[2351]: manager.c:3790 authenticate: 127.0.0.1 failed to authenticate as ‘admin’
[2024-12-15 19:40:29.388] NOTICE[2352]: manager.c:3790 authenticate: 127.0.0.1 failed to authenticate as ‘admin’
