Unable to connect to remote asterisk (does /var/run/asterisk.ctl exist?)
Does - ‘/etc/asterisk/scripts/disconnect’ script have ownership rights ?
…mike/kb8jnm
-------- Original Message --------
Subject: [App_rpt-users] Unable to connect to remote asterisk (does
Date: Thu, December 04, 2014 12:05 pm
To: “app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
I created a simple php file where anyone with the link can disconnect my nose from all links if something wrong is going on (due to the fact my node is same channel, half duplex linked, and if it was stuck on transmit, local transmissions would double with the node)
<?php echo "All links sucessfully disconnected from 40764, KDØWHB test1"; echo '>
// Outputs all the result of shellcommand "", and returns
// the last output line into $last_line. Stores the return value
// of the shell command in $retval.
$last_line = system('/etc/asterisk/scripts/disconnect', $retval);
// Printing additional info
echo '
Last line of the output: ' . $last_line . '
Return value: ' . $retval; ?>
The code was found on the php website as a sample and I just changed ls to my script that works when ran from a normal shell.
Visiting kd0whb.duckdns.org/disconnect.php shows the output of “unable to connect to remote”
Any suggestions?
Skyler, KDØWHB
The script works fine when I run it normally. I also tried to enter the specific command on the web page.
…mike/kb8jnm
echo '
Any suggestions?
Skyler, KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
electricity440@gmail.com
Does the script itself have the absolute command in it? In other words /use/sbin/asterisk instead of just asterisk? That is just an example. I find scripts normally do t work because you don’t have the path and just the command. What will run logged in locally won’t in cron or Apache if you don’t use the directory/command
…mike/kb8jnm
echo '
Any suggestions?
Skyler, KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
nope, thats probably it, the script simply has:
asterisk -rx “rpt fun 40764 *71”
Should I add a /usr/sbin/asterisk -rx "rpt fun 40764 ?
Sent from my iPhone
…mike/kb8jnm
echo '
Any suggestions?
Skyler, KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Yes.
I’m not sure where the script is being called from… But in running scripts via cron, I find that the path to asterisk needs to be used.
Maybe because $PATH isn’t set…
To: “Dean, Corey” n3fe@repeater.net, “rpt-users, app” app_rpt-users@ohnosec.org
Sent: Thursday, December 4, 2014 4:00:43 PM
Subject: Re: [App_rpt-users] Unable to connect to remote asterisk (does /var/run/asterisk.ctl exist?)
I am still getting the unable to connect error after I modified script and tried directly from the php file:
$last_line = system(‘/usr/sbin/asterisk -rx “rpt fun 40764 *71”’, $retval);
( at Kd0whb.duckdns.org/disconnect.php)
