Unable to connect to remote asterisk (does /var/run/asterisk.ctl exist?)
I created a simple php file where anyone with the link can disconnect my nose from all links if something wrong is going on (due to the fact my node is same channel, half duplex linked, and if it was stuck on transmit, local transmissions would double with the node)
<?php
echo "All links sucessfully disconnected from 40764, KDØWHB test1";
echo '<pre>';
// Outputs all the result of shellcommand "", and returns
// the last output line into $last_line. Stores the return value
// of the shell command in $retval.
$last_line = system('/etc/asterisk/scripts/disconnect', $retval);
// Printing additional info
echo '
</pre>
<hr />Last line of the output: ' . $last_line . '
<hr />Return value: ' . $retval;
The code was found on the php website as a sample and I just changed ls to my script that works when ran from a normal shell.
Visiting kd0whb.duckdns.org/disconnect.php shows the output of "unable to connect to remote"
Any suggestions?
Skyler, KDØWHB
Hi,
I have try the Same with Shell_exec(...);
In a php Script with Same Problem.
If anyone Know the Solution, Send it to me too.
Thanks.
73 DL1FLO, Florian
Am 04.12.2014 um 18:05 schrieb Skyler Fennell <electricity440@gmail.com>:
<?php
echo '<pre>';
echo '
</pre>
Any suggestions?
Skyler, KDØWHB
