Unable to Connect My Node to Other Nodes
I just set up a node with a Rasberry Pi connected to a Shari Pi Hat. After completing the setup, I connected to the parrot node 55553 and ran an audio check. However, that is the only node I have been able to connect to. I have tried connecting on the allmon3 dashboard and on the touchtone pad on my radio using the ^3 precursor. My node 69213 appears in the AllStar Searchable Node List with a green dot.
Any help or suggestions would be greatly appreciated.
Thank you,
Dennis W7DAP
I suspect that your node is not registered. Please run asl-node-auth-check for troubleshooting. Post the results here if you need more help.
Name here is Alton, what can you see in this report the troubleshooting script...
[sudo] password for sjr-alton:
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: rpt.conf has configuration for: 67128
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 67128
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 73.147.15.234
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 73.147.15.234
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 73.147.15.234
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 73.147.15.234
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 73.147.15.234
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 73.147.15.234
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 67128:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
OK: register.allstarlink.org is reachable (via HTTP)
OK: HTTP registration state is Registered
OK: Perceived IAX IP:PORT for this node is: 73.147.15.234:4569
OK: Registered to aws-east1a-register2.allstarlink.org - 52.44.147.201
OK: Server-set UDP port matches bindport in iax.conf
OK: Node registration within 10 minutes: 2026-11-02 01:53:04 UTC
Info: Last time IP changed was 2026-02-21 00:20:02 UTC
Warning: Node is not perceived as registered; not tested
Warning: Node 67128 has 1 warning(s)!
Warning: Warnings may or may not be problems depending on configuration
sjr-alton@node67128:~ $
I await your reply...
Are you running the latest software? I believe you're seeing a bug in asl-node-auth-check not a real warning?
perhaps this will tell you something...
what do you see...???
sri, I wanna add this....
OS Kernel : 6.18.50+rpt-rpi-v8
Asterisk : 22.10.1+asl3-3.10.8-1.deb13
ASL [app_rpt] : 3.10.8
Installed ASL packages :
Package Version
allmon3 1.11-1.deb13
asl3 3.18.2-2.deb13
asl3-appliance 2.2.2-1.deb13
asl3-appliance-pi 2.2.2-1.deb13
asl3-asterisk 2:22.10.1+asl3-3.10.8-1.deb13
asl3-asterisk-config 2:22.10.1+asl3-3.10.8-1.deb13
asl3-asterisk-modules 2:22.10.1+asl3-3.10.8-1.deb13
asl3-menu 1.18-1.deb13
asl3-update-nodelist 2.1.0-1.deb13
asl-apt-repos 2.0-1.deb13
cockpit 337-1+deb13u2
cockpit-bridge 337-1+deb13u2
cockpit-networkmanager 337-1+deb13u2
cockpit-packagekit 337-1+deb13u2
cockpit-sosreport 337-1+deb13u2
cockpit-storaged 337-1+deb13u2
cockpit-system 337-1+deb13u2
cockpit-wifimanager 2.0-1.deb13
cockpit-ws 337-1+deb13u2
dahdi 1:3.1.0-2.1
dahdi-linux 1:3.4.0-11.asl.deb13
Something does not look correct...
sjr-alton@node67128:~ $ sudo asl-node-lookup 67128
SRV (_iax._udp.67128.nodes.allstarlink.org)
10 10 4569 67128.nodes.allstarlink.org.
A (67128.nodes.allstarlink.org)
10.0.0.229
TXT (67128.nodes.allstarlink.org)
NN=67128
IP=10.0.0.229
PT=4569
RPT LOOKUP (67128)
[email protected]/67128,NONE
@ KA4JAZ, you have a Proxy IP set for your nodes server.
  • Go to the AllStarLink Portal
  • Select "Portal"
  • Select "Server Settings"
  • Select your nodes server
  • Clear out the "Proxy IP" value
  • Click "Submit"
I wonder if we should do away with Proxy IP. I think that's more confusing for everyone than the tiny handful of people who probably use it.
Thank you to everyone who replied to my post. It was a password discrepancy that has since been fixed. My node is up and running now and seems to be working fine.
Thanks again,
Dennis W7DAP
On Mon, Nov 2, 2026, 9:30 AM N8EI <[email protected]> wrote:
Someone replied to your post.
| N8EI ASL Community Admin
November 2 |
are you addressing KA4JAZ or W7DAP...I am able to connect to a few Nodes, my Allmon3 is not responding....?? Any Help would be appreciated...
Alton, KA4JAZ
You have a Proxy IP set. Delete it.
Hi,
the line you refer to above..?? I have searched though the "Expert Config. Menu" and was unable to find it...?? HELP...which [Stanza] is this line in..RPT LOOKUP (67128)
KA4JAZ, Alton..
I found it in the rpt.conf...deleting it now..
@ KA4JAZ, you need that line in rpt.conf.
Your issue is that you have a Proxy IP set for your server in the AllStarLink portal.
Something does not look right, I deleted the line, restarted asterisk, and this is the reply...
10.0.0.229
NN=67128
IP=10.0.0.229
PT=4569
RPT LOOKUP (67128)
[email protected]:4569/67128,10.0.0.229
what you think..??
@KA4JAZ Please read the posts above, especially Unable to Connect My Node to Other Nodes - #8 by WA3WCO
