Unable to connect in to a 5 digit node
Hello;
    Looking
for a little help again…
I set up my new testing node on 27013. I get failed connects inbound but
it does look like 27013 is registering correctly… outbound seems to
work at least sometimes…
If I recall correctly ( from last night… I was sleepy) 27013 connects to
2235 but not to 2364, neither 2235 or 2364 can call in to
27013…
Is there anything we are going to need to fix in extensions.conf or such
to provide for the mask change of 4 chars to 5 chars in node name??? or
is this some firewall issue again??
Both nodes I am testing with are registered but
When connections come in that are not on port 4569… what do they come
in on as a range??? maybe I need to forward those through my firewall?? I
am using Untangle firewall and port forwarding from anything on the
outside interface destined locally for port 4569 to pass through on 4569
to the inner specified host…
I am pretty sure you guys set up 2235 to only use 4569… this may have
something to do with it…
In the big picture I Would rather fix the firewall to allow other ports
through as needed than lock all to 4569… but if that is what it takes
…ok :slight_smile:
Maybe packets arrive on one port and I am forcing them internally throug
NAT to 4569 and this is messing something up???
Thoughts???
ON a separate issue ( although it does include the same nodes as involved
parties)
27013 is at a separate site from (2235 and 2364) … both sites are
behind a Similarly configured Untangle firewall…
I also have 2 machines on 1 computer 2235 and 2364 and I can connect from
2235 to 2364 but not from 2364 to 2235… being both on localhost
127.0.0.1 it would seem to be an internal problem but scanning the 4 conf
files I cannot see what… both have registrations in iax.conf,
extensions.conf and in rpt.conf… both work individually but I am missing
this…
from extensions.conf
[radio-secure]
;exten => ${NODE},1,rpt,${NODE}
exten => 2235,1,Rpt,2235
exten => 2364,1,Rpt,2364
**************************** By the way… are the “r” in rpt
here case sensitive ??? I have seen listings both
ways**************
[radio-gui]
exten => 2235,1,Rpt,2235|X
exten => 2364,1,Rpt,2364|X
from iax.conf
register=A2235:xxxxxx@register.allstarlink.org
register=A2364:xxxxxx@register.allstarlink.org
; Incoming radio connections
[radio]
type=user
disallow=all
allow=g726aal2
allow=gsm
codecpriority=host
context=radio-secure
transfer=no
from rpt.conf
[nodes]
; no allstar link nodes should be defined here. Only place a
definition
; for your locak nodes, and private (off of allstar link) nodes
here.
2235 =
radio@127.0.0.1/2235,NONE
; This must be
changed to your node number
2364 = radio@127.0.0.1/2364,NONE
; Memories for remote bases
and I have this in line after both node stanza’s so it is duplicated
twice…
statpost_program=/usr/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
statpost_url=http://stats.allstarlink.org/uhandler.php ; Status updates
Any help???
Doug
