uLaw playback
I have read where uLaw produces 14 bit audio (-8159 to +8158
numerically-speaking) - see Wikipedia on this, for example.
I am guessing this is the range of numbers used by app_rpt.
Your 16-bit WAV format is going to produce +/- 32768 (numerically-speaking
again).
So - you need to divide the WAV output by a factor of 4 to get into the
range that uLaw supports.
The tutorial on using Audacity for app_rpt:
http://images.ohnosec.org/app-rpt-audacity.pdf says to normalize at -6dB.
You really need to follow that advice to get clean audio.
"Normalize" will set the loudest sound to the amplitude you select. If
there are a lot of sound "spikes" in the audio track, you can end up with a
pretty low average sound level. I have found the best way to fix this is
some judicious use of the Audacity "hard limiter" function. It really does
not damage the sound quality, when used within reason.
Ken
If the original wav file is not limited to -6 dBfs (minus 6 dB relative to
full scale) you can reduce the level "on the fly" by using the lower case
"v" for volume control.
For example, this reduces the volume to half what it was (-0.5)
sox -v -0.5 -t raw -U -c 1 -r 8000 (etc...)
Ken
Sent: Monday, August 05, 2013 10:39 PM
To: Ken
Subject: Re: uLaw playback
Hi Ken,
Thanks for your reply. I was able to find the syntax for sox. It worked
great. It
took my wav file and converted it over to ulaw. I used :
sox -V n5uxt.wav -r 8000 -c 1 -t ul -w n5uxt.ulaw
It was simple and fast.
73, Angelo
To: <app_rpt-users@ohnosec.org>
Cc: "'Angelo Glorioso'" <n5uxt@hotmail.com>
Sent: Monday, August 05, 2013 7:54 PM
Subject: uLaw playback
speaking
> again).
-6dB.
with
> a
is
does
-----Original Message-----
----- Original Message -----
> 73
> Ken
When I make my audio files in Audacity, I export to a wav file then I export to ulaw.
I then play the wav files back to verify they sound ok.
Works great.
Jon VA3RQ
Ken
To: Ken
Hi Ken,
great. It
73, Angelo
speaking
again).
-6dB.
with
a
is
does
Ken
ohnosec.org
Like a few others on the list here, I'm pretty certain there are a few audio/broadcast/radio engineers in the woodpile, so, while it's good enough to use William or Allison via cepstral, there is nothing like actually, should you want, having a professional production or voice to do fixed announcements. I mean, TTS can only go so far, right?
I know it's overkill (anything worth doing is worth doing to excess...;)), but, I have a complete radio (as in broadcast) studio setup at home; full tape (yes, even carts), a-d conversion, processing (dbx, orban) equipment, dynamic, condensor, ribbon mics, etc., and can deliver in multiple formats (mp3, wav, gsm, etc).
Current studio: http://www.wb0yle.com/photos/streaming.jpg
New console I'm restoring to replace the one in the above picture:
Maybe those of us with the skills, on an as-available and casual basis, can help out those who are 'production facilities-challenged?'???
export to ulaw.
Bryan
In this world, you must be oh so smart or oh so pleasant.
Well, for years I was smart. I recommend pleasant.
You may quote me.
Sent from my MacBook Pro.
