I tried to put the following two lines into my beagle.conf
txtoctype=notone
txctcssdefault=131.8
Now there is a line in the beagle.conf that says:
#includeifexists custom/usbradio.conf
However, as you see it is commented out.
Should those two lines have an effect out of beagle.conf or do I need to add usbradio.conf and remove the uncomment #?
Mike
Kb8zgl
Sent: Sunday, September 16, 2012 12:15 PM
To: ‘Mike Wolthuis’; [email protected]
Subject: RE: [App_rpt-users] TX Tone Drop out Time
Beagle board uses chan_simpleusb
So the config file is: simpleusb.conf
Allegedly it supports the same encoding functions.
See:
http://ohnosec.org/pipermail/app_rpt-users/2011-February/002275.html
Ken
From: [email protected] [mailto:[email protected]] On Behalf Of Mike Wolthuis
Sent: Sunday, September 16, 2012 9:52 AM
To: [email protected]
Subject: Re: [App_rpt-users] TX Tone Drop out Time
Does this work on a Beagle board also do you know?
Mike
Kb8zgl
From: [email protected] [mailto:[email protected]] On Behalf Of Ken
Sent: Sunday, September 16, 2012 7:55 AM
To: ‘Jim W7RY’; [email protected]
This is in usbradio.conf
txtoctype=notone ; Transmit tone control type: no,phase,notone
; phase - encode CTCSS and reverse phase
; AKA (“reverse burst”) before unkeying TX
; notone - encode CTCSS and stop sending tone before unkeying TX
; AKA (“chicken burst”)
If you select notone (as shown here), then the PL drops about 600 ms before the carrier drops.
Most people like it that way
Ken
From: [email protected] [mailto:[email protected]] On Behalf Of Jim W7RY
Sent: Sunday, September 16, 2012 12:05 AM
Subject: [App_rpt-users] TX Tone Drop out Time
I had my PL tone encoder (node generated) drop out before the carrier dropped out. It seems to have quit working. The PL generator is working fine, but the timing seems to changed. I don’t seem to find the command now. I’m probably not be looking in the right file.
Can someone please tell me where that setting is?
Thanks!
Jim W7RY
