Two nodes on same server not connecting
Hello, I just installed ASL3 with node 607390 configured, I added a second node 607391 to be used as an Echolink interface, after finishing configuration and trying to link both local nodes together from CLI with cli> rpt fun 607390 *3607391 I get the following error below, notice how it is trying to connect to 60739, it is missing the last digit 1 in the connection attempt, why?
Thanks in advance
Alex N2IX
app_rpt.c:6310 rpt_exec: Cannot find specified system node 60739
Executing [60739@radio-secure:1] NoOp(“IAX2/201.143.122.150:4569-3319”, “Connect from node: 607390”) in new stack
– Executing [60739@radio-secure:2] NoOp(“IAX2/201.143.122.150:4569-3319”, “Connect to: 60739”) in new stack
– Executing [60739@radio-secure:3] NoOp(“IAX2/201.143.122.150:4569-3319”, “The Channel IP is 201.143.122.150”) in new stack
– Executing [60739@radio-secure:4] GotoIf(“IAX2/201.143.122.150:4569-3319”, “0?connect”) in new stack
– Executing [60739@radio-secure:5] GotoIf(“IAX2/201.143.122.150:4569-3319”, “1?denylist”) in new stack
– Goto (radio-secure,60739,9)
– Executing [60739@radio-secure:9] GotoIf(“IAX2/201.143.122.150:4569-3319”, “0?:connect”) in new stack
– Goto (radio-secure,60739,12)
– Executing [60739@radio-secure:12] Rpt(“IAX2/201.143.122.150:4569-3319”, “60739”) in new stack
[2025-01-16 06:16:17.794] WARNING[3549][C-00000015]: app_rpt.c:6310 rpt_exec: Cannot find specified system node 60739
== Spawn extension (radio-secure, 60739, 12) exited non-zero on ‘IAX2/201.143.122.150:4569-3319’
– Hungup ‘IAX2/201.143.122.150:4569-3319’
– Hungup ‘IAX2/201.143.122.150:4569-3781’
– Hungup ‘DAHDI/pseudo-43436109’
node60739*CLI>
Show your entries of the [nodes] section of rpt.conf
It should not be attempting a radio secure connection since it is a local connection that must be missing definition.
Or perhaps and/or in extensions.conf.
If you use the global variable for node1 you will also need one for node2
You must have a missing entry or a type error you are not seeing.
Thanks for the reply, here is the config for both nodes in rpt.conf, the rest of the parameters are the default ones from the default template:
;;;;;;;;;;;;;;;; Configura tus nodos aquí ;;;;;;;;;;;;;;;;
; Nota: No hay necesidad de duplicar parámetros del templete
; original, solo incluya aquí aquellos parámetros que sean diferentes
; al templete original.
;;;;;;;;;;;;;;;;;;;;;;;;; NODO 607392 ;;;;;;;;;;;;;;;;;;;;;;;;;
607392
statpost_url = http://stats.allstarlink.org/uhandler
idrecording = |iXE2RDX
duplex = 2
rxchannel = SimpleUSB/607392
startup_macro = *3607393
;;;;;;;;;;;;;;;;;;;;;;; NODO 607393 (Pseudonodo de Echolink ;;;;;;;
607393
duplex = 0
rxchannel = dahdi/pseudo
;;;;;;;;;;;;;;;;;;; Your node settings here ;;;;;;;
The extensions.conf file:
[general]
static = yes ; These two lines prevent the command-line interface
writeprotect = yes ; from overwriting the config file. Leave them here.
[globals]
HOMENPA = 999 ; change this to your Area Code
NODE = 607392 ; change this to your node number
[default]
exten => i,1,Hangup
[radio-secure]
;exten => ${NODE},1,rpt(${EXTEN})
exten => _XXXX!,1,NoOp(Connect from node: ${CALLERID(num)})
same => n,NoOp(Connect to: ${EXTEN})
;same => n,NoOp(The IAXPEER is ${IAXPEER(CURRENTCHANNEL)})
same => n,NoOp(The Channel IP is ${CHANNEL(peerip)})
;If channel IP eq localhost go to connect
same => n,GotoIf($["${CHANNEL(peerip)}" = "127.0.0.1"]?connect)
;If allowlist/extension dosen't exist check the denylist
same => n,GotoIf($[${DB_KEYCOUNT(allowlist/${EXTEN})} = 0]?denylist) ;goto denylist
;If allowlist/extension/callerid exists go to connect
same => n,GotoIf(${DB_EXISTS(allowlist/${EXTEN}/${CALLERID(num)})}?connect) ;goto connect
same => n,NoOp(${EXTEN} not in allowlist, Hangup)
same => n,Hangup
;If denylist/extension/callerID doesn't exist goto connect
same => n(denylist),GotoIf(${DB_EXISTS(denylist/${EXTEN}/${CALLERID(num)})}?:connect) ;don't goto connect
same => n,NoOp(${EXTEN} is in denylist, Hangup)
same => n,Hangup
same => n(connect),rpt(${EXTEN})
same => n,Hangup
[iaxrpt]
; Entered from iaxrpt in iax.conf
; Info: The X option passed to the Rpt application
; disables the normal security checks.
; Because incoming connections are validated in iax.conf,
; and we don’t know where the user will be coming from in advance,
; the X option is required.
exten => ${NODE},1,rpt(${EXTEN}|X) ; NODE is the Name field in iaxrpt
[iax-client] ; for IAX VoIP clients.
exten => ${NODE},1,Ringing()
same => n,Wait(10)
same => n,Answer()
same => n,Set(CALLSIGN=${CALLERID(name)})
same => n,NoOp(Caller ID name is ${CALLSIGN})
same => n,NoOp(Caller ID number is ${CALLERID(number)})
same => n,GotoIf(${ISNULL(${CALLSIGN})}?hangit)
same => n,Playback(rpt/connected-to&rpt/node)
same => n,SayDigits(${NODE})
same => n,rpt(${NODE}|P|${CALLSIGN}-P)
same => n(hangit),NoOp(No Caller ID Name)
same => n,Playback(connection-failed)
same => n,Wait(1)
same => n,Hangup
; Comment-out the following clause if you want Allstar Autopatch service
[pstn-out]
exten => _NXXNXXXXXX,1,playback(ss-noservice)
same => n,Congestion
; Un-comment out the following clause if you want Allstar Autopatch service
;[pstn-out]
;exten => _NXXNXXXXXX,1,Dial(IAX2/allstar-autopatch/${EXTEN})
; same => n,Busy
[invalidnum]
exten => s,1,Wait(3)
same => n,Playback(ss-noservice)
same => n,Wait(1)
same => n,Hangup
[radio]
exten => _X11,1,Goto(check_route,${EXTEN},1);
exten => _NXXXXXX,1,Goto(check_route,1${HOMENPA}${EXTEN},1)
exten => _1XXXXXXXXXX,1,Goto(check_route,${EXTEN},1)
exten => _07XX,1,Goto(parkedcalls,${EXTEN:1},1)
exten => 00,1,Goto(my-ip,s,1)
[check_route]
exten => _X.,1,Noop(${EXTEN})
; no 800
exten => _1800NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1888NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1877NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1866NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1855NXXXXXX,2,Goto(invalidnum,s,1)
; no X00 NPA
exten => _1X00XXXXXXX,2,Goto(invalidnum,s,1)
; no X11 NPA
exten => _1X11XXXXXXX,2,Goto(invalidnum,s,1)
; no X11
exten => _X11,2,Goto(invalidnum,s,1)
; no 555 Prefix in any NPA
exten => _1NXX555XXXX,2,Goto(invalidnum,s,1)
; no 976 Prefix in any NPA
exten => _1NXX976XXXX,2,Goto(invalidnum,s,1)
; no NPA=809
exten => _1809XXXXXXX,2,Goto(invalidnum,s,1)
; no NPA=900
exten => _1900XXXXXXX,2,Goto(invalidnum,s,1)
; okay, route it
exten => _1NXXXXXXXXX,2,Goto(pstn-out,${EXTEN:1},1)
exten => _X.,2,Goto(invalidnum,s,1)
[my-ip]
exten => s,1,Wait(1)
same => n,SayAlpha(${CURL(http://myip.vg)})
same => n,Hangup
[allstar-sys]
exten => _1.,1,Rpt(${EXTEN:1}|Rrpt/node:NODE:rpt/in-call:digits/0:PARKED|120)
exten => _1.,n,Hangup
exten => _2.,1,Ringing
exten => _2.,n,Wait(3)
exten => _2.,n,Answer
exten => _2.,n,Playback(rpt/node)
exten => _2.,n,Saydigits(${EXTEN:1})
exten => _2.,n,Rpt(${EXTEN:1}|P|${CALLERID(name)}-P)
exten => _2.,n,Hangup
exten => _3.,1,Ringing
exten => _3.,n,Wait(3)
exten => _3.,n,Answer
exten => _3.,n,Playback(rpt/node)
exten => _3.,n,Saydigits(${EXTEN:1})
exten => _3.,n,Rpt(${EXTEN:1}|Pv|${CALLERID(name)}-P)
exten => _3.,n,Hangup
exten => _4.,1,Ringing
exten => _4.,n,Wait(3)
exten => _4.,n,Answer
exten => _4.,n,Playback(rpt/node)
exten => _4.,n,Saydigits(${EXTEN:1})
exten => _4.,n,Rpt(${EXTEN:1}|D|${CALLERID(name)}-P)
exten => _4.,n,Hangup
exten => _5.,1,Ringing
exten => _5.,n,Wait(3)
exten => _5.,n,Answer
exten => _5.,n,Playback(rpt/node)
exten => _5.,n,Saydigits(${EXTEN:1})
exten => _5.,n,Rpt(${EXTEN:1}|Dv|${CALLERID(name)}-P)
exten => _5.,n,Hangup
[allstar-public]
exten => s,1,Ringing
same => n,Set(RESP=${CURL(https://register.allstarlink.org/cgi-bin/authwebphone.pl?${CALLERID(name)})})
same => n,Set(NODENUM=${CALLERID(number)})
same => n,GotoIf($[“${RESP:0:1}” = “?”]?hangit)
same => n,GotoIf($[“${RESP:0:1}” = “”]?hangit)
same => n,GotoIf($[“${RESP:0:5}” != “OHYES”]?hangit)
same => n,Set(CALLSIGN=${RESP:5})
;exten => s,n,GotoIf($[${DB_EXISTS(whitelist/${CALLSIGN})}]?:hangit) ; Not in whitelist
same => n,Wait(3)
same => n,Playback(rpt/node,noanswer)
same => n,Saydigits(${NODENUM})
same => n,Set(CALLERID(name)=${CALLSIGN})
same => n,Set(CALLERID(num)=0)
same => n,Rpt(${NODENUM}|X)
same => n,Hangup
same => n(hangit),Answer
same => n,Wait(1)
same => n,Hangup
#tryinclude custom/extensions.conf
https://wiki.allstarlink.org/wiki/NNX
This node is not showing as registered.
Verify your registration string in iax.conf with that of your self service portal.
