I am trying to upgrade from another controller software to Allstar Link.
I am running Beta 2.0.0-Beta.6 on a Pi 4 with two USB FOBs. My first attempt was setting up just one Node and it worked fine. Then I edited the .conf files for a second Node and neither Node works now. I have tried to build the configuration 3-4 times with no luck. One of the things that I did was to start Asterisk manually with the -fnvvv options and I get the following errors at the end of the file.
[Feb 5 15:31:10] WARNING[1042]: config.c:774 process_text_line: parse error: No category context for line 1 of /etc/asterisk/extensions.conf
Asterisk Ready.
[Feb 5 15:31:11] WARNING[1048]: config.c:774 process_text_line: parse error: No category context for line 1 of /etc/asterisk/rpt.conf
[Feb 5 15:31:11] NOTICE[1048]: app_rpt.c:22451 rpt_master: Unable to open radio repeater configuration rpt.conf. Radio Repeater disabled.
Any suggestions? BTW, examples of working .conf files from a 2 Node system would be great.
Well Rick,
Let me start by asking if you sutdown asterisk before running it again in the foreground ?
If it is running and you want to see verbose output,
use
asterisk -rvvv
If you want to run it in the foreground,
systemctl stop asterisk
then
asterisk -fnvvv
If that helps any
But let us know where you are from this point.
You likely have made some type error when you set-up the second node.
Perhaps attach your rpt.conf for some more eyes on the file.
Thanks for your quick reply Mike. I did have Asterisk stopped and tried it again with the same errors. I’m a rookie here and don’t see a way to attach my file.
Top of the file [nodes]
(and descriptions under it)
You have moved this to the top and it needs to be at the bottom of the file
Look at one of your old files for guidance.
One stanza describing all nodes described at the bottom.
[nodes]
1331 = [email protected]:4569/1331,NONE ; This must be changed to your node
number
; 1335 added by raa ****************
1335 = [email protected]:4569/1335,NONE ; and iax port number if not the default
put it just above this line #includeifexists custom/rpt.conf
Don't make to many changes at once or you will never sort this out.
Lets see what you have now...
No, that did not help. Strange that I am getting the same context error for all four files that I edited. Extensions, iax, rpt, usbradio. I did the editing on my Linux desktop using a text editor. Maybe I should start over using Nano on the Pi to do the editing?
Thanks for your question Larry. That was my original problem. I was running two Nodes on HamVOIP using a Pi3. I get random lockups with the old system. I wanted to upgrade to a Pi4 but HamVOIP said that there was a problem with 2 nodes.
So, I hoped that Allstar Link would work with the Pi4 and 2 USB FOBs.
Larry, I get the same errors that I got on the Pi4, No category context. Both are running Beta 6. I have not run an earlier version of Allstar link. I inherited the maintenance of our local repeater which was running 2 nodes with HamVoip
Edit to be like so …
exten => 1331,1,rpt,1331|X
exten => 1335,1,rpt,1335|X
Haven’t seen your iax.conf so no comment there.
Also as a comment— Your rpt.conf file reads as quite a jumble and might be a confusion factor for you…
Were it me I would load a basic rpt.conf and copy the pertinent file settings belonging to the main node number.
to the first Stanza within. Once that is done I would copy that whole Stanza from the new rpt.conf and paste the copy at the bottom of the
first Stanza (main node) and then edit the second to utilize the number belong to your second node.
Doing things that way will allow you to tailor different settings for each of the 2 nodes.
Plus if you have problems with one node doing something wrong it is controlled by its own setting and not a shared setting.
That and if running 2 nodes from the same server you will need to define a [nodes] section for each of your node numbers.
In each your [nodes] you will need to indicate a path to the opposite node if you should you ever desire to connect the 2 nodes together.
Thanks for the changes Mike. Good catch on my missing semicolon.
I made the changes but it didn’t help. Still getting the samd “no category context” errors
Thanks for your inputs Larry. I tried removing the parenthesis from the extensions.conf file but it still doesn’t work. I get the same context errors.
What I did was to start with a single Node (radio) and got that working with no problems. Then I followed the instructions in this Wiki “Two Nodes on One Server - AllStarLink Wiki” to add the second node. Now here I am.
I think that I should have asking a different question "Does anyone have a working configuration using one Pi4 to control two nodes using two radios?
