Turn off link connect announcements
Is there a way to turn the announcements of the nodes connecting ans disconnecting in the background? It is probably something simple I am missing .
Mike N6IQY
node 27522
Yes. Add the following commands to each node context in rpt.conf that you want to get rid of the annoying connect/disconnect telem. messages!!
holdofftelem=1
telemdefault=2
This will allow you to hear you own connects and disconnects but it will mute all others after a short delay of playing yours.
This should really be default in the examples! It is in the BBB code. On a large many node connected systems these messages can go on for 10 minutes sometimes. I tis a bit ridiculous!
73 Doug
WA3DSP
Date: Sun, 25 May 2014 20:13:43 -0700
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] Turn off link connect announcements
Mike N6IQY
node 27522
Hi Doug.
10 years later on with ASL3, this doesn’t seem to work. Is there a way to stop announcements of node connections & disconnections for ASL3 & Supermn 7.4+?
Thanks & 73!
Jeff K3JRZ
Yes set your telemdefault=0 in your rpt.conf file. of course this shuts off all telemetry
These are the commands originally intended to control such behavior
.(dtmf numbers may differ in your files as these are old default)
933 = cop,33				; Local Telemetry Output Enable
934 = cop,34				; Local Telemetry Output Disable
935 = cop,35				; Local Telemetry Output on Demand
936 = cop,36				; Foreign Link Local Output Path Enable
937 = cop,37				; Foreign Link Local Output Path Disable
938 = cop,38				; Foreign Link Local Output Path Follows Local Telemetry
939 = cop,39				; Foreign Link Local Output Path on Demand
942 = cop,42				; Echolink announce node # only
943 = cop,43				; Echolink announce node Callsign only
944 = cop,44				; Echolink announce node # & Callsign
