Hello, my name is Bryson with call sign KM6YMM. What I am trying to do is make a neighborhood allstarlink network, I have some people interested (They do have there callsigns) but I am stuck in the config phase. I am trying to avoid using the [nodes] stanza for adding private nodes. Instead I am trying to basically “clone” register.allstarlink.org. I hope this makes sense. I want my users able to use the register command in iax.conf to be able to register to my server. I have posted my current config and what happens with this configuration is when I do *7 it says nothing, not even connection failed. It says absolutely nothing, I sure hope the great community here can give me some tips on to what I am missing. Thank you very much! Configs are below.
Register server iax.conf:
[general]
bindport = 4569 ; bindport and bindaddr may be specified
; NOTE: bindport must be specified BEFORE
; bindaddr or may be specified on a specific
; bindaddr if followed by colon and port
; (e.g. bindaddr=192.168.0.1:4569)
; bindaddr = 192.168.0.1 ; more than once to bind to multiple
; addresses, but the first will be the
; default
disallow = all ; The permitted codecs for outgoing connections
; Audio Quality Bandwidth
;allow = ulaw ; best 87 kbps
;allow = adpcm ; good 55 kbps
;allow = gsm ; medicore 36 kbps
allow = ulaw
allow = adpcm
allow = g722
allow = g726aal2
allow = gsm
allow = ilbc
jitterbuffer = yes
forcejitterbuffer = yes
dropcount = 2
maxjitterbuffer = 4000
maxjitterinterps = 10
resyncthreshold = 1000
maxexcessbuffer = 80
minexcessbuffer = 10
jittershrinkrate = 1
tos = 0x1E
autokill = yes
delayreject = yes
; iaxthreadcount = 30
; iaxmaxthreadcount = 150
; Incoming radio connections
[radio]
type = user
disallow = all
allow = ulaw
allow = adpcm
allow = g722
allow = g726aal2
allow = gsm
allow = ilbc
[1000]
type = friend
context = 1000
auth = md5
secret = Bryson123$
host = dynamic
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
transfer = no
[1001]
type = friend
context = 1001
auth = md5
secret = Melva123$
host = dynamic
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
transfer = no
codecpriority = host
context = radio-secure
transfer = no
#includeifexists custom/iax.conf
Node 1 iax.conf:
[general]
; default
allow = ulaw
allow = adpcm
allow = g722
allow = g726aal2
allow = gsm
allow = ilbc
jitterbuffer = yes
dropcount = 2
tos = 0x1E
autokill = yes
delayreject = yes
register => 1000:[email protected]
[radio]
type = user
disallow = all
allow = ulaw
allow = adpcm
allow = g722
allow = g726aal2
allow = gsm
allow = ilbc
transfer = no
[iaxclient] ; Connect from iax client (Zoiper…)
type = friend ; Notice type here is friend <--------------
context = iax-client ; Context to jump to in extensions.conf
auth = md5
secret = Bryson123$
host = dynamic
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
transfer = no
node 2 iax.conf:
[general]
; default
allow = ulaw
allow = adpcm
allow = g722
allow = g726aal2
allow = gsm
allow = ilbc
jitterbuffer = yes
dropcount = 2
tos = 0x1E
autokill = yes
delayreject = yes
register => 1001:[email protected]
[radio]
type = user
disallow = all
allow = ulaw
allow = adpcm
allow = g722
allow = g726aal2
allow = gsm
allow = ilbc
transfer = no
auth = md5
secret = Bryson123$
host = dynamic
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
transfer = no
register server extensions.conf:
[general]
static = yes ; These two lines prevent the command-line interface
writeprotect = yes ; from overwriting the config file. Leave them here.
[globals]
HOMENPA = 209 ; change this to your Area Code
NODE = 1000 ; change this to your node number
[default]
exten => i,1,Hangup
[radio-secure]
exten => ${NODE},1,rpt,${NODE}
[iaxrpt] ; entered from iaxrpt in iax.conf
exten => ${NODE},1,rpt(${NODE}|X) ; NODE is the Name field in iaxrpt
; Info: The X option passed to the Rpt application
; disables the normal security checks.
; Because incoming connections are validated in iax.conf,
; and we don’t know where the user will be coming from in advance,
; the X option is required.
[1000]
exten => 1000,1,Dial(IAX2/1000)
;[invalidnum]
;exten = s,1,Wait,3
;exten = s,n,Playback,ss-noservice
;exten = s,n,Wait,1
;exten = s,n,Hangup
[radio]
exten = _X11,1,Goto(check_route|${EXTEN}|1);
exten = _NXXXXXX,1,Goto(check_route|1${HOMENPA}${EXTEN}|1)
exten = _1XXXXXXXXXX,1,Goto(check_route|${EXTEN}|1)
exten = _07XX,1,Goto(parkedcalls|${EXTEN:1}|1)
exten = 00,1,Goto(my-ip|s|1)
[check_route]
exten =_X.,1,Noop(${EXTEN})
; no 800
exten = _1800NXXXXXX,2,Goto(invalidnum|s|1)
exten = _1888NXXXXXX,2,Goto(invalidnum|s|1)
exten = _1877NXXXXXX,2,Goto(invalidnum|s|1)
exten = _1866NXXXXXX,2,Goto(invalidnum|s|1)
exten = _1855NXXXXXX,2,Goto(invalidnum|s|1)
; no X00 NPA
exten = _1X00XXXXXXX,2,Goto(invalidnum|s|1)
; no X11 NPA
exten = _1X11XXXXXXX,2,Goto(invalidnum|s|1)
; no X11
exten = _X11,2,Goto(invalidnum|s|1)
; no 555 Prefix in any NPA
exten = _1NXX555XXXX,2,Goto(invalidnum|s|1)
; no 976 Prefix in any NPA
exten = _1NXX976XXXX,2,Goto(invalidnum|s|1)
; no NPA=809
exten = _1809XXXXXXX,2,Goto(invalidnum|s|1)
; no NPA=900
exten = _1900XXXXXXX,2,Goto(invalidnum|s|1)
; okay, route it
exten = _1NXXXXXXXXX,2,Goto(pstn-out|${EXTEN:1}|1)
exten = _X.,2,Goto(invalidnum|s|1)
[my-ip]
exten = s,1,Set(MYADDR=${CURL(http://myip.vg)})
exten = s,2,Wait,1
exten = s,3,SayAlpha(${MYADDR})
exten = s,4,Hangup
#includeifexists custom/extensions.conf
node 1 extensions.conf:
[general]
[globals]
[default]
exten => i,1,Hangup
[radio-secure]
[iax-client] ; for IAX VIOP clients.
exten => ${NODE},1,Ringing
exten => ${NODE},n,Wait(3)
exten => ${NODE},n,Answer
exten => ${NODE},n,Set(NODENUM=${CALLERID(number)})
exten => ${NODE},n,Playback(rpt/node|noanswer)
exten => ${NODE},n,SayDigits(${EXTEN})
exten => ${NODE},n,Set(CALLERID(num)=0)
exten => ${NODE},n,Rpt,${NODE}|P|${CALLERID(name)}
exten => ${NODE},n,Hangup
exten => ${NODE},n(hangit),Answer
exten => ${NODE},n(hangit),Wait(1)
exten => ${NODE},n(hangit),Hangup
;[invalidnum]
;exten = s,1,Wait,3
;exten = s,n,Wait,1
;exten = s,n,Hangup
[radio]
[check_route]
; no 800
; no X00 NPA
; no X11 NPA
; no X11
; no NPA=809
; no NPA=900
; okay, route it
[my-ip]
exten = s,2,Wait,1
exten = s,4,Hangup
node 2 extensions.conf:
[general]
[globals]
NODE = 1001 ; change this to your node number
[default]
exten => i,1,Hangup
[radio-secure]
;[invalidnum]
;exten = s,1,Wait,3
;exten = s,n,Wait,1
;exten = s,n,Hangup
[radio]
[check_route]
; no 800
; no X00 NPA
; no X11 NPA
; no X11
; no NPA=809
; no NPA=900
; okay, route it
[my-ip]
exten = s,2,Wait,1
exten = s,4,Hangup
