Trying to get allmon3 going
I can see allmon3 when on same network with the hotspot. I get an error message a Allmon3 is not responding to requests for this node. Check server logs.
Also I can't get to allmon3 or the Allstartlink Portal when on a different network. Any ideas?
n9gi@pm.me
You need to be a little bit clearer on this. So you say you can see it on the same network, can you log in when on the same network? Make sure to forward the correct port or you will not be able to use Allmon3 from outside of your network. Also make sure you are using your external IP and not your internal when outside the network. Take a look at this post. It may help How to configure allmon3 to listen on specific IP and port and disable ipv6? - #4 by oldunixguy
