Hey guys!
I am building up an AllStarLink node and have come into a problem that I am hoping someone here can assist with. Everything appears to be properly configured, however the node is not connecting to the AllStarLink network. I double-checked my configuration files and network settings, but I am still getting connection issues.
I also check this: https://community.allstarlink.org/t/outgoing-connections-to-nodes-allstarlink-orlooker But I have not found any solution. Could anyone guide me the best solution for this? Has anyone had similar problems or have any suggestions for troubleshooting connectivity issues with AllStarLink nodes? Any advice or suggestions will be highly appreciated.
Thank you in advance.
Respected community member!
