Is there a way to troubleshoot Echolink? I had echolink connected to one of my nodes but decided to move it to another one for technical reasons. Each node has its’ own public IP. I configured all of the ports as they should be in my firewall but after ½ an hour or more, it has not shown back up in the list at echolink. Watching the Asterisk CLI, I see a lot of the following:
The Remote UNIX Connection is you or some process connecting and
disconnecting to the running asterisk process.� (asterisk -rc)
Make sure you remove or rename the echolink.conf file on the node it
used to be on.� Also, try rebooting both nodes.
Try connecting to the asterisk process using a lot of v's on the
command line — asterisk -cvvvvvvvvvvvvvvvvr will work. You can
also use “set verbose 15” to turn it on too.
This will give you a lot of text on the terminal.� Look for messages
from chan_echolink.
You can also issue an "echolink debug level 7" command from the
terminal as well.� This should give you quite a bit of info from
chan_echolink
Stacy
KG7QIN
On 10/27/2015 08:03 PM, Jamey Wright
wrote:
Is there a way to troubleshoot Echolink?� I
it to another one for technical reasons.� Each node has its�
own public IP.� I configured all of the ports as they should
be in my firewall but after � an hour or more, it has not
shown back up in the list at echolink.� �Watching the Asterisk
CLI, I see �a lot of the following:
– Remote UNIX connection
– Remote UNIX connection disconnected���
Jamey
WR4JW
