Greetings. Fresh install from ASL 1.01 on RPi3 B+ this afternoon. radio interface working correctly, IAX2 registered with allstarlink server. however my stats are not posting and I’m getting this message over and over again on the asterisk console:
Do you have more than one node on your server… perhaps node 1999, and is it posting status reports? If so it should not be. Also check you’ve uncommented the stats report for ACID, not Limey by mistake.
Is this about node 49865? It’s not showing as registered at this time.
Be sure these two (and only these two) statpost lines are uncommented under node stanza [49865]
statpost_program = /usr/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null
statpost_url = http://stats.allstarlink.org/uhandler.php ; Status updates
Yes sir, It’s specifically 49856. I didn’t have a node 1999 defined in ASL. Didn’t need to un-comment as the stock 1.01 ASL image for the RPi already had it uncommented. Verified that the Limey stuff was commented and only the two lines you gave were uncommented. As a test, I loaded the hamvoip distro on the RPi and it posts stats now. not sure what gives. It’s obviously not the servers. Going back to ASL 1.01, no stats and the error I provided above persists. Something in the code or hidden in the config. I thought for a moment I had figured it out when I discovered that there were a bunch of blank characters after the statpost_program line, but that didn’t seem to change anything. I’m at a loss.
Some build notes: Stock Asl 1.01 image on RPi3B+. Used asl-menu to install the system. Selected usbradio for the interface and gave my credentials, etc. and that’s it.
I’ve been accused of a thing or two, yes.
Yes, wget is installed, stock image. I even tried to replicate the command interactively. no error back. the php parts I didn’t get right, but at least wget took the arguments.
Correct. I turned it off last night, so not registered. I’m re-burning the image again right now.
interesting… during setup i chose SimpleUSB for the radio driver and things started working with the stats page. I was choosing UsbRadio previously. let me re-try again from fresh install. maybe there’s something in the asl-menu setup/config that I’m hitting. give me a few to re-load the image.
I’ve reloaded from image file twice this morning. both times the stats started working.
Last night I reloaded several times the same way, stats didn’t work.
loaded hamvoip distro, stats started working.
this morning moved back to ASL, and viola! stats continue to work…
not sure what that all means… guess nothing currently to see here…
